Question about Amana ACE14 Microwave Oven
Clean filter indication
How do you re-set the clean filter indication?
The reset filter light came on for my LG microwave. What do I do?
Check your user manual. It should describe how to reset this light. These types of service filter indicators are activated after a set amount of time determined by the manufacturer has elapsed. The microwave has not actually detected a dirty filter, it's just a reminder that its time to clean the filter.
Dec 13, 2017 | LG Microwave Ovens
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
Mar 14, 2014 | Maytag MMV5208W Microwave Oven
Machine says CALCIF What does it mean?
CALCIF usually indicates "calcification" which is a buildup of calcium and other minerals. I don't believe you would normally see this indication on a microwave oven. Coffeemakers often indicate mineral buildup by indicating "DESCALE" or similar.
Descaling or removing mineral deposits in a coffeemaker usually requires running the coffeemaker with white vinegar instead of water, and no coffee ground or filter. Three or four "brewings" is usually all that is needed to remove the deposits. Simply run several more brewing cycles of clean water to rinse all the internal components of any vinegar and the job is complete.
If this answer isn't applicable - please tell me model number of the appliance that is displaying the CALCIF message, otherwise, please rate my reply "4 thumbs up" if it was helpful Thanks!
Aug 15, 2011 | Siemens Microwave Ovens
My husbands wants to know how to clean the air filters that are under the spacemaker icrowave oven and above the stove ?
If your unit is venting to the outside, you would be using one or two grease filters, which can be cleaned, usually with warm soapy water.
If your unit is set to recirculate, then you should be using a charcoal filter, which cannot be cleaned, and must be replaced.
Details and instructions are to be found in your owner's manual.
If for some reason you don't have yours, you can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (including filters) by entering your full model number here.
Apr 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
Is there a filter that goes into the vent of GE Spacemaker 2.0 profile microwave (model# JVM2070SK01)?
You should first refer to your owner's manual. If for some reason you don't have it, you can download it here free.
See page 38 and 39 of the manual for info on the filters.
If your oven is set up to vent outside, it will have cleanable grease filters.
If it is set up to recirculate, it will have a charcoal filter which cannot be cleaned, but must be replaced about every 60 days.
It is part number WB2X10956 and you can order it and other parts and accessories here.
Dec 17, 2010 | GE JVM2070 Microwave Oven
Is there a filter that can be repaced in this model
If your unit is set up to ventilate to the outside, there should be a metal grease filter, which should be cleaned in hot soapy water whenever it gets greased up.
It's important to be sure that your ductwork and outside vent flapper are clear, too. Animal nests can block them.
If it is set up to recirculate, it should have a charcoal filter in it, and those should be replaced (they cannot be cleaned) about every six months or so, depending on your usage.
You can download GE owner's manuals and installation instructions here.
Sep 30, 2010 | GE XL1800 1100 Watts Microwave Oven
How to set it to high, med or low
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
May 27, 2010 | Microwave Ovens
GE Microwave oven JVM1440BH01 vent does not draw fumes from the stove top even though motor is running and air is coming out of the top vent.
Your grease filter or charcoal filter may be clogged.
I would refer you first to the owner's manual, then if everything is set up right, you may need to clean the filter (if it's a grease filter) or if it;s a charcoal filter, it will have to be replaced.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 29, 2010 | GE Microwave Ovens
Frigidaire plmv169dcd not venting properly. Filters are clean.
If it's equipped with a charcoal filter, that needs to be changed (not cleaned) about every 6-12 months, depending on use.
I would also very the installation and venting set up found in the installation instructions.
You can download Electrolux/Frigidaire owner's manuals and installation instructions here.
If all that is proper, then I would suspect an obstruction such as an animal nest in the vent outlet or in the duct work.
Feb 14, 2009 | Whirlpool GH7145XF Microwave Oven
Amana ACE14 Microwave Oven Logo
24 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
