Question about Thermador Cooktops
How to remove chrome top around burners on Thermidor SGC365RS
Remove chrome top
2 Suggested Answers
AndrexT
  • 20318 Answers
SOURCE: NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Posted on Jan 24, 2016
Testimonial: "THE GAS WAS TURNED OFF. DUH! WHAT ELSE DO YOU KNOW."
How to remove the top panel of the cooktop?
To remove the top so that you can replace the electrodes, you just need to pull all the burner grates off and knobs. Then remove all the burner caps and rings off so that all you're left with is the cooktop and the burner bases. There are screws going into each burner base. Remove all the screws and the burner bases will pull up and off and then you can pull the top of the cooktop up and off.
Feb 13, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Removing a dacor imfered burner
tis a big job for consumer, but gain access to bottom of unit and remove anything holding it to countertop. then remove unit from counter and set it over the hole at an angle. then around the box under the cooktop glass are screws. remove them and the glass top will lift off. MAKE SURE THE POWER IS OFF. the rest should be apparent as to how to remove. be careful good luck
Jan 03, 2012 | Cooktops
HOW DO YOU REPLACE BURNER SWITCHES? REMOVE ENTIRE UNIT FROM THE COUNTER TOP, OR IS THERE A WAY TO JUST REMOVE GLASS TOP TO ACCESS SWITCHES?
Take off the switch nobs and center grate, then carefuly lift the glass up/ start on one edge first. Have a towel or pillow to rest the glass once off it is around 250$ to replace glass!
Dec 22, 2010 | Jenn-Air JED8430 Electric Cooktop
Parts Replacement
twist the burner to releace them . remove all 4 and the screws around the sides the lift top .. cook tops have to be completly disambled . for service .. mm
Jun 29, 2010 | Maytag MGC5430BDS Gas Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
How do you get the black top off. I have to put in a new front burner. Thanks.
I had the same problem. Mine was caused by liquid seeping into the infinite switch (the switch that gets rotated by the knob to set burner temperature). This caused one of the live wires to short to ground within the switch. Bad Design IMHO. Replacing the switch fixed the problem (you can get replacement parts at Searspartsdirect.com - search using the cooktop model number).
You first need to remove the unit from its installation. Start by disconnecting the exhaust fan from the ductwork. Then push the cooktop up.
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also in the down draft cavity (the down draft cavity is where the grease guard mesh is)
Turn off the circuit breaker to the cooktop. Verify by making sure the burners/fan do not come on. Disconnect the exhaust fan (underneath the cooktop) from the ductwork by removing the tape that joins it. While you are underneath the cooktop, open the junction box. Label the four wires that are joined so that you will be able to connect them later. Then disconnect the four wires. Remove the metal sheating that connects to the junction box (there is a nut on the inside of the junction box that you loosen. Pull out all the supply wires (from the mains) from the junction box. Then push the cooktop up and out and lay it flat on a table with the flat side down.
Take off only the top row of screws all around the unit. Rotate the unit so that you can get to the down draft cavity (the down draft cavity is where the grease guard mesh is). Remove the two center screws. Then pull the black top off.
For an exploded view of the unit check out
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47639&diagram_id=681565#d681565
Sep 03, 2009 | Jenn-Air JED8430 Electric Cooktop
Burner out in whirpool black glass cooktop
take the whole cooktop out there should be screws around the base you take them out, seperate the bottom from the glass you should be able to get to the element to check if it is bad by ohming it out
May 01, 2009 | Cooktops
Jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
Romvoing the top of my Whirlpool Cooktop
first thing is the spark module(ignitor-- your referring to) is probably good and your electrodes are damaged. more then likely the problem. when you turn on one burner they should all spark( 1 module controls all 5 electrodes) so lets check that, first. when you turn on any/all burners do you at least hear clicking??. theres a switch under each **** that turns on the spark(erhaps one of them is bad. think of the electrodes as spark plugs on a car, they spark the same way, ck to see that they are clean(free from rust and carbon build up).using emory cloth or a woman's finger nail file try "sanding" down to a shiny surface the very tip of the electrode protruding out of the burner head.look for cracks in the porcelin housing around the electrodes this will lead to miss fires of the electrodes
Mar 11, 2008 | Cooktops
Thermador wcggcv30 gas cooktop - how to remove glass top
Remove the brass ring nuts and the screw from each of the burners and pull off the knobs, then lift up the glass cooktop; no need to remove the three screws around the perimeter or even take out the box.
Nov 23, 2007 | Cooktops
Cooktops Logo
61 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
tom wright
tom wright
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
