Question about NEC Dtp 8-1 Dterm Series E Black PhoDtp-8-1 bk
Mic doesn't work
When I use the speaker the people can not hear me
NOT RECEVING OR TRANSMITING
Can you see the s-mete if it has one moving up and down on any channel? Do you hear any audio at all? could be a couple of things. Bad mic switch or mic cable, bad antenna or coax, bad audio amp. To check the audio amp plug in a speaker to the PA jack, put the PA switch on PA then press the mic to talk. If it works the audio is fine the mic is good and the mic cable is good. Noiw plug the speaker into the speaker jack, do you hear anything? If not then your antenna or coax has a problem, fix or replace antenna or coax.
Jan 04, 2013 | Radio Communications
I only use the pa function.it doesn't always work.mic prob?when i switch to cb-no prob.
What type of PA speaker are you using? what OHM? and wattage.. A cb pa can only supply MAX 5watts into a pa speaker. It may be too big of speaker or bad speaker? if it works on cb.. wrong OHMS can make problems too..
Nov 15, 2011 | Radio Shack TRC-447 CB Radio
My contacts cannot hear me. Also message comes up and says microphone is very quiet and contacts may not hear
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure mic to chat program
Jun 18, 2010 | Creative Labs Live! Cam Video IM Pro...
Webcam audio works one way
You have a laptop and it has a built in mic
You need to nominate your webcam mic as default
TEST SPEAKERS
Restart computer
CONFIGURE TO YOUR CHAT PROGRAM
May 07, 2010 | Logitech Webcam
Other person cannot hear me
You are in a situation of having 2 mics
Make sure the webcam mic is set as default
TEST SPEAKERS
Restart computer
Configure mic to your chat program
Apr 28, 2010 | Logitech Webcam
My speaker stopped working after some time!
may be problem in lose wire connection ,
check that first.
may be there is a problem in mic from where u talk,
open the mic cover smoothly,check all the wires are joint if not join it properlt,
still problem take off ur mic and check with speaker or with other equpiment like ur mobile headset,if mic is ok then put back, if not do *
join wires again properly,next
open joiner where the speaker and mic are joined,may be there are some wire disconnection join it ,if properly joined,
* then there is a problem in mic
replace the mic with same type of mie or u can use the mic of ur mobile head set or find it someware ,
join it ploperly.
it works.
goodluck
email rushi_jky@yahoo.com
Apr 28, 2010 | Cyber Acoustics AC401 Consumer Headset
My chatmate can hear me but i can hear her
might be ur speaker is not intgrated with mic give it for service
Dec 22, 2009 | Yahoo Messenger
Was working at first but now sound is too quiet
check mic level on recording mixer for windows N.B. r-mixer different from playback-mixer
Apr 05, 2007 | Sony FV100 Consumer Microphone
NEC Dtp 8-1 Dterm Series E Black PhoDtp-8-1 bk Logo
20 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
