Question about Voicezone Deluxe Talking Pedometer
Voice zone talking pedometer stopped working. Replace new battery, still doesn't work. Opened it up, a tiny metal wire came off, lokks like it was attached to a plastic arm and I am not sure where els
What else do you need o know?
What batteries do i need for my centrios talking pedometer
I finally found the centrios talking pedometermanual which should provide it with the batteries. You could download it here.
Mar 08, 2013 | Radio Shack Digital Pedometer
Need instructions for voice zone he9965
How do you turn the volume down on the radio? Is there a built in volume control.
Mar 04, 2013 | Voicezone Talking Calorie Counting...
Beeping won't stop in Sportline 370 pedometer
Use MODE button to scroll to ALM (alarm) then press INFO button to change from ON to OFF. If that doesn't work use MODE button to scroll to PACE, then press INFO button to toggle from ON to OFF.
Feb 27, 2012 | Sportline 370 Traq Motion Sensor Pedometer...
I have a maxi aid Talking pedometer and can't figure out how to turn the alarm off
You can cycle threw all the Alarm sounds buy pressing the "UP and DOWN" buttons simultaneously until you hear the "Alarm off" voice, also you will see the little "Bell display" above and between the hours and minutes go away.
Sep 14, 2011 | Maxi Aids Talking Pedometer
I recently changed my Solenoid on my 1990 Ford F150 and I accidentally put the battery post on the wrong terminals on the battery and the fusible link wire connected to the alternator started smoking and...
first of all change the fusible link, there should be 2 others so follow the positive wire connected to the battery , if any of these blow out, the mapping of power stops at them
May 13, 2011 | Ford F-150 Cars & Trucks
It can not start working
if you tried a new battery,and it wont fire up you may need to send it to olympus for service,or buy a new one
Mar 24, 2010 | Olympus VN-2100PC Digital Voice Recorder
My HJ720IT pedometer screen is blank. I thought the battery had died but got a new battery and it still won't work.
Mine has same problem. Died a week ago. Put in new battery and it worked for a week. Now it is dead again.
Dec 23, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
Voicezone talking pedometer instructions, turn off alarm
Push both the up and down buttons at the same time. You might have to repeat this two or three times. It will tell you when the alarm is off.
Jun 22, 2009 | Exercise & Fitness
I have a 2002 jetta gls 2.0 My driver side brake light does not work all of the time. Its works only sometime. The other day I opened the trunk to lokk at the wiring harness and it looked fine. Then when I...
locate the ground wire for that socket... it should attach to a metal part of the frame not far away... remove the screw... clean surfaces with a wire brush or simiilar ... then attach it firmly with the screw...
Please take a moment to rate this solution
Jan 27, 2009 | 2004 Volkswagen Jetta
Voicezone Deluxe Talking Pedometer Logo
24 people viewed this question
Top Voicezone Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Voicezone Exercise and Fitnes Expert? Answer questions, earn points and help others
