Led light not working
Power going to machine but not switching on
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
How do I reset a brother HL 5450 printer
try download manual from brother site:
http://support.brother.com/g/b/manualtop.aspx?c=eu_ot&lang=en&prod=hl5450dn_all
it is something specific what you want reset? toner? drum? or the printer? all of that is available in manual.
Mar 02, 2015 | Brother HL-5450DN Laser Printer
My power led connector (green,white) power sw connector (black,white) got out of place and i dont where they go
The eMachines T3302 desktop computer, uses an FIC K8M-800M motherboard.
(First international Computer, Inc.)
Where those wires go on the motherboard, is termed a Front panel header.
The Front Panel is the plastic front bezel of your computer.
(Where the Power On button is, Power On LED light, and so on)
Looking at the motherboard with the Processor to the Top, Ram Memory slots to the Right, the Front Panel header is at the bottom right corner, and over to the left.
Look at the jumper block in the bottom right corner. Right in the corner.
This is the LED type selector, jumper block.
Has 6 pins.
3 across the Top, 3 across the Bottom.
(This jumper block is to set whether you are using a Power On LED light, that has Dual Colors, or a Single color.
The default setting of the jumper on the block, is set to use a Dual Color LED light, for the Power On LED)
Move to the left of this jumper block. The Front Panel header is to the left of this jumper block.
(FIC terms it a Front Panel Block Connector)
It should be White in color.
Is right against the bottom edge of the motherboard. (Parallel to the outside edge of the motherboard)
Has two rows of pins sticking up.
5 across the Top.
4 across the Bottom.
The pins are numbered from the Right, going towards the Left.
(From the Power On LED jumper block, towards the Front Panel header)
On the Top row going from Right, towards the Left,
Pins 1 ,3, 5, 7, and 9.
On the Bottom row going from the Right, towards the Left,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the Power On LED light.
Pin 1 is for the Positive ( + ) wire.
(Green)
B) Pins 5 and 7 are for the Power On switch.
Pin 5 is for the Positive ( + ) wire.
(Black)
[Although it really doesn't matter which way the wires go. It's a SWITCH]
C) Pins 2 and 4 are for the HarDDrive activity LED.
Pin 2 is for the Positive wire ( + )
D) Pins 6 and 8 are for the Reset switch.
(IF used)
If any of your LED lights are dim, after attaching the Positive wire for each LED, it's because the Positive wire is on the wrong pin.
Switch the wires around
Aug 23, 2010 | E-Machines T3302 PC Desktop
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hello i have a e-machine T3103 the three set of
There is a small block of pins usually on the bottom right corner of the mother board to hook up front panel connections, you will have to read the board around it and somewhere it will tell you which wires go where.
Mar 02, 2010 | E-Machines Computers & Internet
My t2862 powerlight will not come on but a green led comes on on the main board, nothing else happens. I also disconnected the pwr sw,hdd led and pwr led plugs and don't know which pins they go on. Thanks
On the front panel header where the wires connect, there are two rows of 5 pins. The top row actually has 4 pins with the end one missing, and the bottom row has 5 pins. The first two pins on the top row are for the power LED. The next two pins are for the power switch. The first two pins on the bottom row are for the hard drive LED, and the next two pins are for the reset button (if your machine has one). The LED connections are polarized, so if you get the connector backwards the LED won't light but it won't be damaged. Just turn the plug around and put it back onto the pins if your power light or drive light don't work.
Now, as to the computer not starting. Assuming the problem isn't due to the power switch not being connected correctly, you might have a power supply problem, or the motherboard has failed. Both are common troubles.
Here's a picture (from helpwithpcs.com) of the plug on the cable from the computer power supply to the main board:
This is the view from the end looking at the front of the plug. If you connect the pin marked PS_ON (it's a green wire) to the black ground wire on either side (not directly across), the power supply will turn on and its fan start running if it's working properly. If it doesn't start up, replace the power supply.
If the supply starts normally, your motherboard is likely to blame. You can search online for a replacement if you want to use the exact part. Don't try to get one from e-Machines; there many other sources. You can also use any motherboard that will fit into the case (micro-ATX style) and uses the same processor and memory.
Sep 27, 2009 | E-Machines T2862 PC Desktop
Need help
the pin arrangement is 4 pins and pins.
From left top row (4 pins) first 2 are power led, next 2 are power switch, next 1 is empty
from left bottom row ( 5 pins ) first 2 are hdd, next 2 are reset, next 1 is empty.
The connectors for the power led and the hdd produce a light, if they don't produce a light, power off your pc and switch the cables round the other way and power on again.
Oct 30, 2008 | E-Machines (308714) Motherboard
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
