Question about LG NB3520A Soundbar 300W Bluetooth w-sub
Pair 300 soundly Subwoofer will not pair with the soundbar... Manual says to press the Stop Button on the soundbar and the mute button on remote.... Yet it doesn't say "Remate" like it says it would..
It worked, then after you shut off, it doesn't work
I do not have the remote to my lg bluetooth soundbar subwofer anymore and they arent pairing can you help please
Press and hold PAIRING in the back of subwoofer for more than 5 sec,
until LED on subwoofer blinks red and green alternating.
Unplug the power cord of the soundbar and the wireless subwoofer.
Connect then again after the LED of the main unit and the wireless subwoofer fully turned off.
Jul 06, 2017 | LG Cell Phones
Can't sync my JBL SB400 subwoofer to the soundbar??....it flashes blue and goes back to orange. Sound bar works but can't pair sub!..HELP!!
PAIRING THE JBL SB400 FOR WIRELESS OPERATION
After turning the soundbar and subwoofer on for the first time, you will need to "pair" the subwoofer and soundbar so they both operate at the same wireless frequency. To pair the units, press the Wireless Pairing switches on both units within 30 seconds of each other. The units will communicate with each other and operate at the same frequency.
May 21, 2015 | JBL Audio Players & Recorders
Subwoofer not working.
Most likely, the "remote" wire to the subwoofer amplifier has come off or is not making good connection.
May 15, 2015 | JVC TH-BA1 Soundbar System with Wireless...
SOUND BAR IS ON BUT SUBWOFFER DOESNT WANT TO TURN ON RED LIGHT IS ON BLUE LIGHT NOT ON
turn the soundbar off, then press and hold the reset button on the back of the subwoofer until the blue light starts blinking fast. the point the remote at the soundbar and hold the mute button until"ID SET" shows on the display. Then turn on the soundbar and it should find the sub and pair with it.
Sep 12, 2014 | Samsung HWE450 Wireless AirTrack Sound Bar
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
The blue light still continues to flash
Push in and hold the switch on the back of the subwoofer until the light starts blinking fast. Then, with the soundbar power turned off, hold the mute button on the remote. "ID SET" should show up on the display. Then turn on the soundbar, and the subwoofer should link to it.
Oct 31, 2013 | Samsung 40" AudioBar w/ Wireless Subwoofer...
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
Pairing my lsb316 sound bar and subwoofer
There is a button on the back of the sub that you need to press to complete the pairing..the led will be green when paired successfully or red if it is in standby mode
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Yamaha yas-101 uverse codes
I had the same problem with my U-verse s10-10 remote and a yamaha SR 300 soundbar. Here is how I got my volume control (but NOT power control) on the yamaha working:
First - always send volume control to the AUX button:
Press and hold AT&T key and OK for 1 second, release, look for 2 flashes.
Now press AUX button. The AUX button will show a long flash.
Second - Go through the manual programing steps listed in the guide for the AUX button (hold AUX and OK for 1 second, release; 2 flashes, punch in code). But instead of pressing the Power button to try to turn off your yamaha soundbar, press the volume up / down and Mute button. I think the code that worked for me was 4045 but I honestly don't remember.
The key is that you have to send the volume control to the AUX button first or it's all a wash.
Jun 26, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
LG NB3520A Soundbar 300W Bluetooth w-sub Logo
75 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
