Question about Maytag PYE2300AY Electric Dryer
Smelled burning/it stopped/won't start back
Won't start
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
Cabrio washer door won't open!
if you plug it back in.... set at any cycle it should release then unplug asap. the aggitor/drum belt is what you are smelling.
Feb 14, 2018 | Whirlpool WTW5700XW Cabrio HE Washer
DRYER WON'T START
you need a new heating element just had mine fixed did the same thing
Sep 28, 2012 | Frigidaire Electric Dryer
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
My Kennmore 79363 Gas Range/ Electric Oven electrical doesn't work. Started smelling electrical burning smell, tracked to oven. shut off breaker, smell stoped. Few hours later checked again after...
The person who installed the oven didn't do the connections up tight enough.
I would replace the breaker/power switch with a new one and trim back the wires if the burning is in the breaker. If on the rear of the oven, same applies with badly tightened connections.
If in doubt, call a qualified electrician. That will be better than having a fire!
Aug 06, 2017 | Kenmore 79363 Gas Kitchen Range
The coils in back turn red hot and smells like it is burning
Here is a tip that I wrote about why an electricdryer will not stop heating sometimes.
ElectricDryer won't stop heating
heatman101
Aug 15, 2011 | Frigidaire FER311FS Electric Dryer
Washing machine stopped spinning after several loads, and I smell a slight burning smell, won;t drain either.
it sounds like u might have some electrical problem in the controls however it may be the pump itsself has gone out but if u r getting an electrical smell could be causing the pump not to get power or the pump has burnt up causing the wires to get hot and start to melt myy bet is that the pump has gone out its not horribly bad to change out but kind of difficult for someone who isnt used to doing this kind of stuff
Feb 25, 2010 | Washing Machines
Maytag dryer problem
sounds like the motor. if the motor gets too hot then the overload on the motor wont let it come back on until it cools off
Nov 25, 2007 | Dryers
Maytag PYE2300AY Electric Dryer Logo
23 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
