Question about Ice Watches
Ice watch opening
Battery replacement opening back
2 Suggested Answers
  • 4135 Answers
SOURCE: I need to get the back off my new ice watch to replace battery but I can't? Anyone know how please?
Waterproof or water resistant watches usually need a wrench to unscrew the back. I use a pair of 90 degree circlip pliers. A jeweller would remove the strap and fit the watch into a holder before using the wrench.
Few jewellers would guarantee the water resistance of a watch after fitting a new battery. If it is required a watch be returned to its original specification it must be returned to the manufacturer or an agent for battery fitting and pressure testing.
Some watches have a back that is pressed into place. Fairly easy to prise off but very difficult to replace without the tools. This type does not have the grooves a wrench fits into.
Posted on Apr 10, 2016
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
Apr 10, 2016 | Ice Watch Watches
Ice watch that i cannot open
you can open your ice watch most likely with a sharpen knife, but be carefull.
AED ARS AUD BRL CAD CNY DKK EUR MXN NZD NOK COP GBP RUB CHF USD JPYMy...
Mar 31, 2014 | EOS Ice Watch In
How do I open the back of the watch to replace the battery & what type battery does it take? Thanks Ian Lawes
Usually the back of a watch is sealed with simple screws. Just unscrew them with a jeweler's screw driver and it will open the battery compartment of the watch.
The battery depends on what type of watch you are using. The most common batteries for watches are about less than 3/8 of an inch.
Mar 04, 2011 | Watches
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    Dead battery, how do I open?
    I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
    Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
    the details of the battery read on top the one currently inside it.
    Jan 30, 2010 | Watches
    Battery....can I get a battery replacement anywhere?
    Most Skagen watches have a snap-in, snap-out back. You will need a tool to open the back such as a slotted jeweler's screwdriver or knife blade to pry it open. Be careful opening the back as the battery may pop out. Examine and make note of which side of the battery is up. Get the number off the battery, or take the battery with you to Wal-Mart, Radio Shack or anywere else they sell batteries. Buy a replacement, install it, and try to reinstall the back. You may even consider taking the watch with you to the above retailers...some of them are willing and able to change the battery for you.
    Dec 08, 2008 | Skagen Watches
    Concord Impresario battery replacement
    The watch has a tiny screw holding the back of the watch. You must use a very small jeweler's screwdriver to open it carefully and replace the battery.
    Aug 04, 2008 | Watches
    Watches Logo
    18 people viewed this question
    Top Ice Watches Experts
    Ansel Alberto
    Ansel Alberto
    TIC TOCK SERVICE
    TIC TOCK SERVICE
    Bill Boyd
    Are you an Ice Watch Expert? Answer questions, earn points and help others
