Question about Dell Studio 1747 Notebook
Touch screen does not work
Touch is not enabled for my notebook
TOUCH SCREEN DOES NOT WORK
There are three (3) possible Answers:
First: Your unit does not have TouchScreen.
If the part number has CF30xTxxxxx then the "T"=TouchScreen.
If your unit has touchscreen then,
Second: The TouchScreen may be disabled in the BIOS.
Check the BIOS and see if TouchScreen is "ENABLED".
If it is DISABLED, then ENABLE it usually by pressing
the spacebar key while it is highlighted and then
SAVE and EXIT the BIOS.
Third: You do not have the Touchscreen Drivers loaded.
Locate these drivers at the Panasonic Website:
http://pc-dl.panasonic.co.jp/dl/
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Mar 17, 2014 | Panasonic Toughbook CF-30 Notebook
How do i turn the "touchscreen" off on an Asus S200E vivobook touchscreen laptop? please i need help urgent!
Press the Windows logo key + X.
Click the little arrow next to Human Interface Devices to expand the list.
Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
Right-click, and select Disable from the list.
Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable
Sep 26, 2013 | ASUSTeK COMPUTER Asus VivoBook...
My touch scroll stopped working for my Gateway NV53A. Can I fix it?
1_9_2013_6_10_09_am.jpeg check it first , by , connect a mouse , go control panel disable it , and use mouse ,turn the notebook , turn on & enable it , may be works , other wise hardware problem.
Jan 09, 2013 | Gateway Computers & Internet
How to turn cq56 touch pad on/off
You might try to touch the screen/pad and hold your finger down for 5 seconds. Also, lok in Device Manager to ensure that it is enabled, else it will not work.
Cheers!
-a.
Apr 09, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
How to set up mouse pad so it works with touch
Check in the control panel under mouse. There should be a setting to enable tapping. If there is a touch pad icon on the bottom right of the screen you can also right click on that and select options.
Dec 31, 2008 | Gateway MT3705 Notebook
Broken ts
yes you can take the glass out but leave the plastic that protects the screen. but remember your touch screen wont work if the glass is not replaced which can be a bit expensive
Dec 23, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
Laptop mouse
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Mar 15, 2008 | Acer Aspire One PC Notebook
Enabling computer mouse
did u hit fn key or botten above mouse turn the mouse on ??> buy usb one mini
Jan 16, 2008 | Toshiba Qosmio G25-AV513 Notebook
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Dell Studio 1747 Notebook Logo
18 people viewed this question
Alun Cox
