Question about Thetford Norcold RV Cooler/Freezer
Ref.will not turn on
Has ll op code
Black ops 2 cheat codes
A good site to get them at is gamewinners. It is some times there are no actual cheat codes but tips, hints and FAQ's for games. http://www.gamewinners.com/Cheats/index.php/Call_Of_Duty:_Black_Ops_2_(Xbox_360)
Jun 16, 2014 | Microsoft XBOX360 By Yallstore
OP ERROR CODE FOR ELECTROLUX REF
Hello scarter517 - Typically error code OP indicates that the freezer sensor is in an open position. A professional would need to check the wiring between the thermistor and board. If correct, the thermistor may possibly need replacing.
Nov 20, 2012 | Washing Machines
Black ops cheats
Greetings,
For an extensive list of cheats, codes, and walkthoughs for Black Ops (PS3), visit this site. Thank you for using FixYa.
Sep 20, 2012 | Activision Call of Duty Black Ops
I am getting error code ll trying to find out if it is worth paying somebody to fix it Describe your Neptune FAV6800AW Top Load Washer Problem
If it a FAV6800A or FAV9800A I can..........What is the error code.......DC, UC OD, OP? Is the machine banging around in spin cycle of the wash cycle. Be as detailed as you can with the problem description.
How handy are you or do you? Do you know someone that has basic mech. skill sets and can help you?
Aug 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Hi, I'm Holly and i have been trying to get onto facebook for that past few days. I can get on my phone but for some reason the lap top i am on wont log in anymore. I keep getting an Error in...
Try this:
In Internet Explorer, go to Tools -> Internet options -> Advanced tab. Check "Disable script debugging," click "Apply," then OK. Then try it again.
Ben
May 10, 2011 | Microsoft Internet Explorer 8
Mine says OP even though the locked signal is on too! i ahve tried WD 40, unplug and plug power on but do not seem to succed. I unlatched the door open and even jiggled with the locks. nothing doing.
Have you placed some external magnets on the Left grey
bumper and see if you can clear the OP error cord. I assume you powered cycle the machine.
If that doesn't clear the OP error code it would be time to;
1. Confirm the 12VDC on the control board is good.
2. If good see if 12VDC is making it back to Conn_3 Pin 9 down to the LF Hand Lid Lock and thru the Magnetic Reed relay back to the Control Board Conn_3 Pin 9.
Before you go thru all that did you open the Left Lid Lock and make sure the Black lead on the magnetic reed relay did not break off from corrosion issues. I know I have a number of post on this board related to troubleshooting the left hand lid lock..................Rick
But some pic's for ref;
How to check that the magnetic reed relay is closing with you DVM.
I'm on P1 and P2 of the left hand lid lock. Those pin are referenced to the schematic jut for my troubleshooting info.
Oct 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The washer is stuck locked. When turned on it shows OP where the minutes are!! PLEASE HELP !!
Don’t force the lid open and break the lid locks.
Here is the Service Manual and parts look up;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Use this procedure for releasing the washer top from the base;
Un plug the 120VAC power cord to the washer.
To raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
This will get the clothes out.
With the washer top raised gently push to Left and Right lid lock latches to outside of the lid the unlock position.
You can now lower the washer top to the base.
Do you want to DIY the OP error code?
The OP error code could be caused by a Lid Magnet out of position. To do a quick check with the lid open power up the washer. Do you have the OP error code showing? If so take a large magnet and place it over the grey left lid bumper and see if the OP error code will clear the LED display. A Pic for reference;
If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
e830e40.jpg If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Jenn air ref side by side everything in ref freezing up model jcp2292htb
Hi
Thanks for using FixYa. This issue means that something is wrong with the compressor of the Refrigerator. You’ll need to take off the lower back access panel by pulling the unit out. There is a plastic box attached to the compressor with wires going to it. You’ll need to remove the Overload Relay Assembly and shake it. If it rattles then you’ll need to replace it and if it doesn't shake then you’ll need to replace the compressor.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Refrigerators
Thetford Norcold RV Cooler/Freezer Logo
20 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
