Question about Vantec NexStar-3 External 3.5inch SATA&USB2.0 Hard Drive Enclosure (Black) (NEWITEM58149860) Drive Case
Beeping & win 7 not detecting
When power is on , beeping and wont start
Tip
Dell Vostro 1000 Bios - Flash Failure
I attempted to update the BIOS on my Vostro 1000 to cure the bad battery message. My original BIOS was 2.6.1 and I intended to update to 2.6.3.
I could not flash under Windows 7 so I installed XP but the flash failed half way through.and the computer did not power up again. All that happened after I pressed the power switch was the light came on and the CD drive shuffled a couple of times. No screen illumination.
Various posts were scanned but no solution found until my buddie came up with the following sequence.
Get the file posted in this link on a computer running XP
http://hotfile.com/dl/113520903/05689ed/VOSTRO1000_CRISDISK.ZIP.html
To Create a Crisis Recovery USB you must use a Win XP system
Note: Running XP through compatibility more in Win 7 will not work
1. Insert Blank USB Drive
2. Open "CRISDISK" folder
3. Open "WINCRIS" application
4. It should detect the USB Drive
5. Click "Start" Button WINCRIS should create the USB recovery drive
6. For Crisis recover, be sure to Power drain system.
. A. Remove Battery
. B Depress power button for 10-15 sec.
7. Insert USB drive into USB port of the Dell.
8. Hold END button while plugging in power cord in system
9. Continue to hold END and depress and release the system power button.
10. Continue holding END until USB drive begins to flash and a single beep is heard.
11. System may remain blank as it enters recovery mode - Anoying Beeping will be heard - Beeping will stop and FANS will function Another series of Beeps will be heard
12. System should complete recovery in 5-10 min. If system has not powered down in 15 min, power down by pressing the power button
This worked for me and as a bonus I do not have the battery error message anymore.
on Apr 06, 2011 | Computers & Internet
Hp 6500a wont scan in win7 32bit
Make sure you have installed the scanner drivers for win7. I have the same printer and I can print & scan from Win XP, Win 7 & my iPad (All on wireless). Drivers for the printer & scanner must be installed.
Jan 27, 2014 | HEWLETT-PACKARD 6500A Plus InkJet Printer
Dell inspiron 15 beeps 7 times
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 23, 2012 | Dell Inspiron 15 Laptop Computer- Intel...
Trust Webcam 16588 Not Working on Windows 7
click start right click on computer select properties device manager scroll to image devices right click to update driver software
hope it helps
May 08, 2012 | Trust MultiCover WideScreen HD Webcam...
Can not (re)install HP Solution Center in windows 7 (photosmart c6280)
check leads and connection points
once connected windows 7 should automatically detect your printer search for and install the drivers
click start control panel devices and printers if you see your printer right click on it
you might have to set it as your default printer
click start right click on computer device manager scrollto ports com & lpt
if you see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed
hope this helps
Dec 12, 2011 | HP Photosmart C6280 Printer
I installed Dell Vostro 1000 System BIOS, v.2.6.1, A04 on myDell Vostro 1000. When it was finished the screen went black and it won't start. Now what? is the computer ruined?
Yep I did the same. Finally recovered using the link shown below.
A. Remove Battery
B. Depress power button for 10-15 sec.
7. Insert USB drive into USB port.
10. Continue holding END until USB drive begins to flash and a beep is heard.
Good luck Dean/Steve
Mar 11, 2011 | Computers & Internet
Web cam not detected in acer aspire 1410 laptop
when i change win 7 64 bit to win 7 32 bit. my webcam not detected. how can i open it. please help me
Jan 01, 2010 | Acer Aspire 1410-8414 Netbook
Vantec NexStar-3 External 3.5inch SATA&USB2.0 Hard Drive Enclosure (Black) (NEWITEM58149860) Drive Case Logo
79 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
Willem.
Willem.
Piyal Perera
Piyal Perera
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
