Question about Fujitsu fi Office Equipment & Supplies
E4 Motor fuse malfunction
What does a "E4 error: motor fuse malfunction" mean?
SOURCE: E4 error code
How do I reset base and make phone usable again?
Posted on Oct 02, 2008
SOURCE: LX-18 error code E4 what is the problem?
the water does not seem to be pumping to wash the dishes....could something be plugged? I can hear the pump and it pumps the water out at the end...
Posted on Mar 06, 2009
  • 158 Answers
SOURCE: konica minolta bizhub 162 have error C0000(main
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Posted on Nov 30, 2009
Testimonial: "yes this is right ! i figer out the problem - it was in development unit! tNx"
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: motor error on lexmark printer c540
    Motor error comes up when motor of the printer fails to turn or run. Here's what you can do:
    Run motor detect (NOTE: You may need to run motor detect procedure two or three times to be successful.). To run motor detect, you need to go to the Diagnostic Menu.
    1. Turn the printer off.
    2. Press and hold Left and Select.
    3. Turn the printer on.
    4. Release the buttons when the installed memory and processor speed displays. Scroll down to Miscellaneous Tests. Press the select button
    Motor Detect
    This test initiates an automatic motor detection process that should be performed whenever the controller board
    is replaced.
    To run Motor Detect:
    1. Remove the imaging unit and the waste toner bottle.
    2. Reinstall the right cover assembly.
    3. Close the front cover.
    4. Enter Diagnostics menu (Turn the printer off, press and hold Left ( ) and Select ( ), turn the printer on,
    and release the buttons when the installed memory and processor speed displays.
    5. Select MISC TESTS in the Diag Menu, and press Select ( ).
    6. Select Motor Detect, and press Select ( ).
    If you press Select before closing the front cover, a message appears: Close Cover. Press Select.
    Motor Detection In Progress… appears.
    The motor detection process takes about 10 seconds, and stops automatically.
    Detect Complete. Rebooting… appears, and the printer performs a POR (Power On Reset).
    If the motor ran, the test was passed. If the motor did not run, the test failed. If problems persists, the printer might need to be serviced or exchanged depending on the warranty/entitlement.
    Posted on Apr 14, 2010
    Macmarkus
    • 2605 Answers
    SOURCE: Error message: E4....What means? I can't open the
    Hello, Welcome to FixYa.
    Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck. The E4 error indicates a door kock error, however the door typically locks as a result of the unit failing to drain, so....
    1. **Unplug the washer from the wall or turn off the breaker before attempting any repairs**
    2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)try a drill bit or small screwdriver that fits in the hole in the round door.
    3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
    4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
    **NOTE - you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan
    Once the door is open, unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets". Good luck !
    Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly. (Sorry about the post, I'm still adapting to this "htc" windows 7 phone after having an iphone for 2years...very tricky lol )
    Thank you for choosing to "FixYa".
    Regards,
    Macmarkus :)
    Posted on Jul 16, 2011
    My ricoh photocopier machine is giving error code 522 pls what is the solution
    Quoting link:
    "This error is a fusing thermistor error, it can mean:
    The fusing lamp is not connected. Reconnecting it may solve the problem.
    Thermistor is bent or gone bad. You may need to replace it.
    Or, the thermistor position is incorrect.
    To try and reset the code press:
    Clear Mode, 107, Clear/Stop and hold for 5 seconds."
    http://terraofficesolutions.com/forum/index.php?topic=7.0
    http://www.thecopierexchange.com/2017/01/updated-ricoh-error-codes/
    Code
    Possible Causes
    SC500Main motor/transport motor lock/Fusing motor error
    SC501Drawer 1 lift motor malfunction
    SC5022nd or 1st tray lift motor malfunction
    SC503Drawer3(or 2nd) lift motor error
    SC504Drawer 4 or 3rd lift motor malfunction
    SC505LCC Tray malfunction
    SC506Paper tray motor lock
    SC507LCT main/feed motor lock
    SC508Rear fence drive motor
    SC509Drawer 3 LCT right fence error
    SC510LCT lower limit error
    SC511LCC motor lock
    SC515Drawer left guide drive motor error, Tandem rear fence motor error
    SC516Drawer 1 side guide motor error
    SC520Paper tray error/Duplexer jogger drive motor error
    SC521Duplexer jogger driver motor error 2
    SC522Duplex-Side fence jogger HP error
    SC524Duplex-End fence jogger HP error
    SC530Bypass feed motor lock/fusing fan motor error
    SC531Fuser/Duplexer reversing motor error
    SC541Fuser thermistor open/ Hot Roller thermistor open
    SC542Fuser Temperature warm-up error
    SC543Fuser overheat error1
    SC544Hot roller fusing lamp lower limit temperature detected
    SC545Fuser lamp overheat error 2
    SC546Fuser ready temperature malfunction
    SC547Zero cross signal malfunction/ Fusing temperature does not increase
    SC548Fusing installation error
    SC550Fusing web end
    SC551Pressure roller thermistor open
    SC552Pressure roller warm up error
    SC553Pressure roller overheat
    SC554Pressure roller low temperature abnormal
    SC555Pressure roller ready temperature abnormal
    SC557Pressure roller temperature does not increase
    SC558Zero cross signal abnormal
    SC590Exhaust/Fusing fan motor error/used toner collection motor error
    SC591Toner supply motor error
    SC592Toner bank motor error
    SC599Copy exit tray motor lock
    Troubleshooting Tips:
    SC500:Too much load on the drive mechanism
    Some gears or other rotating parting has been jammed.
    Developing unit is over toned.
    Main motor or its driving board is defective.
    Before replacing motors or sensors, first check the mechanical load.
    SC 541:Fusing thermistor open:
    Machine is plugged into low line voltage.
    Fixing thermistor is defective or out of position.
    Some loose connection
    Power Supply board defective
    SC590:Left exhaust fan motor error
    Loose connection of the exhaust fan motor.
    Too much dust in the fan causing too much load on the motor driver.
    (e) 6XX: Communication errors
    CodePossible Cause
    SC600Communication Error Between Main Control and Operation Panel Boards
    SC634Key/ Card Counter Device Error
    SC636Communication Error Between BICU & Paper Feed Control PWA
    SC696Communication Error Between Engine Boad and Finisher
    SC621:ADF connection error
    An incorrect ADF is installed on the machines.
    The connector of the ADF is removed while the machine is in the energy save mode.
    (f) 7XX: Peripherals Problems
    CodePossible Cause
    SC700RADF Original Pickup Malfunction
    SC702RADF Feed Motor Lock
    SC703RADF Transport Motor Lock
    SC704RADF Original Exit Motor Lock
    SC705RADF Bottom Plate Motor
    SC721Sorter Bin Motor
    SC722Finisher/Sorter Jogger Motor
    SC727Finisher Stapler Rotation error
    SC728Finisher paper stack height error
    SC733Finisher Lower Tray lift Motor
    SC760ADF Gate Abnormal
    SC770Display Editor Abnormal
    SC700:ADF pickup problem
    Home sensor is defective
    ADF board or pickup roller mechanism is defective.
    SC733:Finisher lower tray lift motor
    stack height sensor or lower tray limit sensor may cause this problem
    (g) 8XX: Controller Errors
    CodePossible Cause
    SC800Startup Without Video output End
    SC804Startup Without Video Input End
    SC818Watchdog Error, Software Malfunction
    SC819Kernel Mismatch, Download Firmware again
    SC820Self Diagnostic Error,Download Firmware again
    SC855Wireless LAN card problem detected
    SC857USB Interface Error Detected
    SC868Incorrect Data is detected in the SD card
    SC870Address Book Data stored on the hard disk was abnormal
    SC 826:Self diagnostic error:
    NVRAM on the controller board is defective and must be replaced.
    SC855:Wireless LAN card error
    Poor Connections between LAN card and the printer
    Defective controller board.
    Defective wireless LAN card.
    Disclaimer:
    Please note that this detail is just for information. Do not try to repair a machine if you are not a qualified technician. Technicians should also not take this information as a substitute of technician manuals.
    May 02, 2018 | Ricoh Office Equipment & Supplies
    Machine error E04-03
    E4-03 is an error in the fuser (HOT ROLLERS) section of the machine. Could be a bad fuser motor, loose connector, an open fuse or dirty thermistor. Does the machine have a bad paper jam right now? That will cause the motor not to turn. Hope this helps
    Jul 11, 2011 | Panasonic DP-C322 Copier
    2 error codes on 2008 nissan sentra p2101 and p2118 what do these codes mean? only has 24,000 miles on the car
    code P2101 (which is a Throttle Actuator Control Motor)
    Trouble Code: P2118
    Electronic Throttle Control Motor Circuit Malfunction
    Trouble Code Conditions:Ignition is on and ETC motor is not in limp-home mode. When the PCM detects an internal error or short between the ETC motor and ETC motor positive circuits in the ETC motor driver. The ETC light will be flashing.
    Possible Causes:
    • Throttle plate or bore malfunctions
    • ETC positive circuit is open or is shorted to ground, battery voltage or ETC negative circuit
    • ETC negative circuit is open or is shorted to ground or to battery voltage
    • ETC motor has malfunctioned
    • PCM has failed
    Oct 23, 2010 | Nissan Sentra Cars & Trucks
    H5-01 error on sharp AR-M450N
    Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
    Apr 01, 2010 | Sharp AR-M450N Copier
    Error codes E1 to E5
    E1: tape end detection LED open
    E2: front loading motor lock
    E3: loading motor lock
    E4: cylinder motor lock
    E5: reel motor lock
    These are from a Panasonic AG-7500 service manual.
    Mar 04, 2010 | Panasonic Televison & Video
    Printer displays c-0096 on display
    C0096 Image Transfer Belt pressure/retraction failure
    please have this services as this is a part of the printer that is not consumable.
    Code Item
    C0000 Main Motor’s failure to turn
    C0001 Main Motor turning at abnormal timing
    C0016 Bk PC Motor’s failure to turn
    C0017 Bk PC Motor’s turning at abnormal timing
    C0018 Color PC Drum Motor’s failure to turn
    C0019 Color PC Drum Motor’s turning at abnormal timing
    C001A Color Developing Motor’s failure to turn
    C00l B Color Developing Motor’s turning at abnormal timing
    C0040 Suction Fan Motor’s failure to turn
    C0046 Fusing Cooling Fan Motor/1 failure to turn
    C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
    C004C Ozone Ventilation Fan Motor’s failure to turn
    C004D Toner Suction Fan Motor’s failure to turn
    C004E Power Supply Cooling Fan Motor’s failure to turn
    C004F Cooling Fan Motor 2’s failure to turn
    C0060 Fusing Drive Motor's failure to turn
    C0061 Fusing Drive Motor turning at abnormal timing
    C0094 2nd Image Transfer Roller pres-sure/retraction failure
    C0098 Fusing Pressure Roller pressure/retraction failure
    C0200 Cyan PC Drum Charge Corona malfunction
    C0202 Magenta PC Drum Charge Corona malfunction
    C0204 Yellow PC Drum Charge Corona malfunction
    C0206 Black PC Drum Charge Corona malfunction
    C0208 PC Drum Charge Corona malfunction
    C0400 Exposure Lamp’s failure to turn ON
    C0410 Exposure Lamp turning ON at abnormal timing
    C0500 Heating Roller warm-up failure
    C0501 Fusing Pressure Roller warm-up failure
    C0510 Heating Roller abnormally low temperature
    C051 1 Fusing Pressure Roller abnormally low temperature
    C0520 Heating Roller abnormally high temperature
    C0521 Fusing Pressure Roller abnormally high temperature
    C0650 Scanner Home Sensor malfunction
    C0660 Scanner overrun failure
    C0900 Tray3 Elevator failure
    C0910 Tray2 Elevator failure
    C0950 Tray4 Elevator failure
    C0960 Bypass lifting motion failure
    C0990 LCT Elevator Motor malfunction(Elevator malfunction)
    C0991 LCT ascent motion failure(soft limit error)
    C0996 LCT Shift Motor malfunction
    C0997 LCT shifting failure
    C0998 LCT ejection failure
    C099C LCT Shift Gate malfunction
    C099D LCT communications error
    C0805 Finishing option Paddle Motor malfunction
    C0B20 Finishing option Stapler Unit CDdrive failure
    C0B2S Finishing option Stapler Unit SlideMotor malfunction
    C0830 Finishing option Aligning Bar moving mechanism malfunction
    C0B39 Finishing option Front AligningMotor malfunction
    C0B3A Finishing option Rear AligningMotor malfunction
    C0B48 Finishing option Exit Roller pressure/retraction failure
    C0B4A Finishing option Storage Roller pressure/retraction failure
    C0B4C Finishing option Exit Motor malfunction
    C0B50 Finishing option stapling mechanism malfunction 1
    C0B55 Finishing option Staple/Folding Motor malfunction
    C0B75 Finishing option Punch Cam Motor drive failure
    C0B76 Finishing option Punch Unit Board malfunction
    C0B77 Finishing option Punch Side Registration Motor malfunction
    C0B78 Finishing option Punch Motor malfunction
    C0B79 Finishing option Punch Sensor malfunction
    C0B80 Finishing option Shift Motor mechanism malfunction
    C0BA0 Finishing option Elevator drive malfunction
    C0F30 Abnormally low toner density detected Cyan ATDC Sensor
    C0F31 Abnormally high toner density detected Cyan ATDC Sensor
    C0F32 Abnormally low toner density detected Magenta ATDC Sensor
    C0F33 Abnormally high toner density detected Magenta ATDC Sensor
    C0F34 Abnormally low toner density detected Yellow ATDC Sensor
    C0F35 Abnormally high toner density detected Yellow ATDC Sensor
    C0F36 Abnormally low toner density detected Black ATDC Sensor
    C0F37 Abnormally high toner density detected Black ATDC Sensor
    C0F3A Cyan ATDC Sensor adjustment failure
    C0F3B Magenta ATDC Sensor adjustment failure
    C0F3C Yellow ATDC Sensor adjustment failure
    C0F3D Black ATDC Sensor adjustment failure
    C1200 Standard controller configuration failure
    Cl 203 File Memory mounting error
    C1204 Memory capacity discrepancy
    Cl 220 Image Input Time Out
    C1229 Image Output Time Out
    C1240 JBIG0 Error
    Cl 241 JBIG1 Error
    C1242 JBIG2 Error
    C1243 JBIG3 Error
    C1250 Compressor 0 command buffer stop failure
    C1251 Compressor 1 command buffer stop failure
    C1252 Compressor 2 command buffer stop failure
    C1253 Compressor 3 command buffer stop failure
    Cl 261 Compression hardware timeout
    C1265 Extraction hardware timeout
    C1279 PCI-SDRAM DMA operation failure
    C1290 Compression/extraction timeout detection
    C12B1 Image processing ASIC failure 1
    C12B2 Image processing ASIC failure 2
    C12B3 Image processing ASIC failure 3
    C12B4 Image processing ASIC failure 4
    Cl 2C0 Hard disk recognition error
    C12C1 Hard Disk Error 1
    C12C2 Hard Disk Error 2
    C12C3 Hard Disk Error 3
    C12C4 Hard Disk Error 4
    C12C5 Hard Disk ErrorS
    C12C6 Hard Disk Error 6
    C12C7 Hard Disk Error 7
    C12C8 Hard Disk Error 8
    C12C9 Hard Disk Error 9
    C12CA Hard Disk Error A
    C12CB Hard disk data transfer error
    C12CC Hard disk unformat
    C12CF Hard disk specifications error
    C12D0 Controller hardware error
    C13C8 New Transfer Cleaner Unit reset-ting failure
    C13CA New Fusing Unit resetting failure
    C13D1 Cyan Imaging Unit EEPROM access error
    C1302 Magenta Imaging Unit EEPROM access error
    C13D3 Yellow Imaging Unit EEPROM access error
    C13D4 Black Imaging Unit EEPROM access error
    C13D5 Cyan LPH correction data down-load failure
    C13D6 Magenta LPH correction data download failure
    C13D7 Yellow LPH correction data download failure
    C13D8 Black LPH correction data download failure
    C1800 Controller start failure
    C3310 CCD clamp/gain adjustment failure
    C3331 MSC undefined malfunction occurring
    C3332 Scanner Section undefined malfunction
    C3333 Engine Section undefined malfunction
    C3E00;C3E01;C3E02 NVRAM initialization failure
    C3F00 Vendor connection failure
    C3FFC ROM contents error upon startup(LPH)
    C3FFD ROM contents error upon startup(Scanner)
    C3FFE ROM contents error upon startup(PRT)
    C3FFF ROM contents error upon startup(MSC)
    Aug 14, 2009 | Office Equipment & Supplies
    I have a Sears Pro Form 730si. The treadmill
    I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
    Jul 14, 2009 | Exercise & Fitness
    Malfunction detected C-0096
    Code Item
    C1240 JBIG0 Error
    Cl 241 JBIG1 Error
    C1242 JBIG2 Error
    C1243 JBIG3 Error
    Feb 10, 2009 | Kyocera Office Equipment & Supplies
    Riso ks800
    e4-ink over flow. solution-clean ink sensor.
    e3-clamp motor locked. solution-use code 64
    Sep 21, 2008 | Office Equipment & Supplies
    Error code
    sure is it e4 20?
    or maybe e3 20?
    if this error alway displays, it means that your machine is having problem with main motor rotation, pls contact your service provider.
    May 23, 2008 | Panasonic DP-6010 All-In-One Printer
    75 people viewed this question
    Top Fujitsu Office Equipment & Supplies Experts
    Chris Larocque
    Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
