Question about Brother XL-3030 Electronic Sewing Machine
The machine will not stitch. It looks as if it's sewing but when I look at the fabric to check, there's nothing there. Just a line of holes where the needle has punctured the fabric. The underside of
I've rethreaded the machine, tried different thread, different fabric, and a different stitch. Nothing has helped. I also adjusted the bobbin tension slightly which didn't help- but maybe I didn't do it enough.. I've had problems with the tension before and didn't want to mess with it too much in case I couldn't get it back where it needs to be. Is this machine just getting too old? It's probably close to 12-15 years.
  • 39 Answers
Have you made sure that your bobbin thread is going into the case going back on itself rather than threading directly into the bobbin case slit. This creates tension. Also check the thread take up as you hand wind the fly wheel. If the tp and bottom threads are not catching each other from the bobbin hook then it could be that the timing has gone out of sync. If you can get hold of a Readers Digest sewing book there are good operational drawings of how the bobbin and needle coordinate.
Posted on Mar 28, 2014
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
rochelle0099
  • 5 Answers
SOURCE: tension problem on Brother ES 2000
I have a Brother CE 4000 Computer sewing machine. I had the same problem when I first used it. I worked with it several hours but to no avail so I decided to stop and wait until my head clear..
I went back a couple of days later. Reread the manual and started over. I discovered my problem was that I was threading the bobbin wrong. Once I threaded it precisely as the manual stated it worked fine.
So this might be your problem. Make sure that the thread on the bobbin is wind on properly. It should be wound evenly. The bobbin must be threaded precisely as the manual says.
Try rethreading the bobbin and the machine
and see if that help.
Posted on Jul 30, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
  • 1788 Answers
SOURCE: When i start to sew
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Posted on Sep 25, 2010
Have Pfaff 7570. Can I sew 4 holed button?
If it is a flat button that will fit under the presser foot, of course you can stitch it down with your sewing machine. (I like to use gluestick from the school supply bin to stick the button to the fabric.) Be sure to deactivate the feed dogs while you are sewing on buttons.
You'll just need to stitch two button holes and then rotate the fabric & button and stitch the other two holes.
How to Sew on Buttons With Your Sewing Machine Sew4Home
Oct 27, 2016 | PfaFF Creative 7570
Can you gather
You can always gather on a sewing machine, no matter its age or model.
Usually, I like to set the upper tension looser so the upper thread shows on the bottom of the fabric. Set the straight stitch length to very long. Stitch two lines of stitching about 1/4" apart on the fabric.
how to gather fabric
How to Gather basic sewing tutorial
How to Gather Fabric Sewing Machine
Apr 29, 2016 | Sewing Machines
Machine not sewing properly
Did you check the adjustment for the stitch "tightness"?
Jul 31, 2015 | Sewing Machines
Bernina buttonhole 730
Use your ruler and measure your button. Then transfer those measurements to your garment.
Use chalk to mark the center cut line of your button hole. Mark the end or stop point of the button hole per the measurement.
Practice on a scrap of the same fabric before you begin on your garment.
Set your machine the satin stitch zig zag at a fairly narrow width.
Begin satin on one side of the center line of the mark. Slowly stitch down that side until you get to the end. STOP. Widen your satin stitch to the max. sew about 1/8" and stop with the needle down on the opposite side to your first line of stitching. Turn the fabric, narrow the stitch to match original satin stitch. Sew slowly down the other side of the center mark. STOP, lengthen the stitch, sew 1/8" then do a couple back stitches.
That's one way. Another older way is to sew 2 or tree straight stitch lines around the center line. Remove then use a hand rendered button hole stitch after you cut the hole.
Oct 27, 2013 | Husqvarna Sewing Machines
Kenmore 385 81808 sewing machine will run, but stiches do not appear on fabric.
try changing the needle--make sure it the right needle for the fabic
being sewed
also try rethreading the sewing machine top & bobbin
make sure to use every thread guide
make sure the bobbin is turned the right way in the bobbin case
it's also possible that the sewing machines timing needs to be
checked at a sewing machine shop
Oct 04, 2012 | Sewing Machines
My handy stitch will not sew,,all mechanical parts work,,holes in fabric...but thread will not sew onto fabric??
Might be off timing, check that needle is right direction, timing sometimes on these units are thrown off easy
Jul 23, 2011 | As Seen On TV Handy Stitch Mechanical...
My singer does'nt do dverlockWhat can I do ?
No sewing machine does a true overlock stitch, that is what sergers are for, they trim and form a stitch on the edge of the fabric using 1 or 2 needles and two loopers. Costs more for an additional machine but the finish is much more like a shop bought item.
tally_girl_14.jpgi
Some sewing machines have an overcasting or interlock stitch which looks like stitch 10 in this picture above. Your machine may have this stitch?
If not, does it have a three step zig zag? It looks like a zig zag but the needle goes into the fabric three times as it forms each leg of the zig zag. This stitch is great for neatening a raw edge and I use this a lot myself. Especially on wovens as it is always faster to seam with this rather than the overcasting stitch where the feed dogs move the fabric forwards, then backwards, then forward to make the stitch.
The sewing machine made overcasting stitch can be used to sew knit fabrics, attach rib around an neck line and neaten raw edges but it is always going to take longer than a serger and there is no trimming function so its never going to look like a shop made overlocked item. However, you can sew knit fabrics with a sewing macine with a bit of patience as long as the machine has some "Forwards/backwards" type stitches as these put elasticity into the seams - if you seam knit with a straight stitch, seams can break when under tension during wear.
And use a twin stretch needle and straight sttich to sew the hems, this looks a bit like a cover stitch and has a bit of give in it too.
Hope this helps you a little. You can find some good sewing general info on www.sewing.about.com or invest in a good sewing book. I refer to my Vogue Sewing Manual and my Singer Sewing Secrets often. Or take a sewing class, its a great way to learn new things, get enthused and have fun.
Apr 08, 2011 | Singer 3116 Simple
Skipping stitches and knotting up underneath.
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
Hope this helps.
Sep 23, 2009 | Janome Sewing Machines
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
