Question about Motorola Mobility H202 Cordless Phone
Delete missed calls
Can i delete missed call
How to delete missed calls and sms'e from Huawei P8lite phone
Open the calling app.
Press the button on the right bottom corner just under "#" that has 3 lines.
Then press "View By."
Then "Missed Calls."
Then press that 3 line button again.
Then "Delete call log."
Then "Select All."
"Delete"
Voila
Oct 10, 2016 | Huawei Cell Phones
I have a wall at&t phone and the missed calls keep adding up . How can I delete the rising number
Look online for a user manual, or check the menu on the phone to see if there is an option to delete, or not show, missed calls.
Dec 08, 2014 | AT&T Lands Phones
HOW DO YOU CLEAR RECENT CALL AND MESSAGES
Hi trsampson,
To clear recent calls, here are the steps to follow:
1. Go to the 'Menu' option.
2. Scroll, till you get to call register.
3. Select it, then scroll to 'delete recent call list'.
4. After you have selected it, you would be provided with the options to delete,
i. 'All calls', selecting it would entirely wipe off your entire call log.
ii. 'Missed call', selecting it would delete your entire missed call on the call log.
iii. 'Received calls', selecting this deletes all your received calls.
iv. 'Dialled calls', selecting this deletes all your dialled calls on d log.
You could also perform selective deleting. You might want to delete a/some paticular number(s) that is on the log, not the entire log.
To effect this, after step 2 above, you can scroll to either of 'missed calls', 'received calls', or 'dialled calls'. Select the one which pertains to the number you want to delete, scroll through till you get to the particular number(s), select 'options', scroll till you get to 'delete', then select delete, and the number is deleted. Do it for as many numbers as you want to be deleted.
To clear messages,
1. Select the menu option, scroll till you get to 'messages'.
2. Select 'messages', scroll for either 'inbox' or 'sent messages'.
3. Select whichever you want to delete from, scroll to the particular message, and select 'options', sroll again, and select 'delete'.
Hope that helped?
Success.
May 09, 2011 | Motorola Cell Phones
I am unable to delete specific call from nokia C5 log" can some one help
Hello ,
You can do this by following these steps :
1) Go to Menu --> Log --> Recent Calls
2) Select the required option (1.Missed Calls 2.Received Calls 3.Dialled Numbers)
3) Now you'll see a detailed list of all your network communications for the past 30 days of the calls depending upon the option you selected , i.e. if you have selected Missed Calls , you will get the list of missed calls.
4) Using the navigation keys select the highlight the entry you want to delete.
5) Use the 'Left selection key' on the keypad to select 'Options'
6) You will get a list of options which includes the 'Delete' feature.
7) Highlight the delete feature and use the left selection key to select it.
8) Confirm your action in the coming alert box and you're done.
Feb 14, 2011 | Nokia C5 Cell Phone
How can i delete just one missed call not all my missed call plz i need yr help
Go to menu, then find the Log in your phone's menu, Select the Log, then inside the Log you will see the All calls, then under All Calls you'll see the Missed call, select the Missed call, then select the number you wish to erase, select the option then select the delete.
Hope this one helps. Thank you for using Fixya.
Oct 21, 2010 | Nokia X3 Cell Phone
How can i delete missed calls in motorola l6
In Motorola, L6, we cant see the missed calls separately. they will be shown along with the received calls.
we cant delete only the missed calls at once..
we can manually delete them by this process as all know..
Press UP navigation key, it opens the received calls menu,
if you see a Tick mark beside a number or name, it represents a received cal,
it you just see the number or name without a Tick mark, it represents a missed call..
you can delete them by selecting options and delete..
Jul 08, 2010 | Motorola Mobility L6 Cellular Phone
Can't see missed calls anymore. some times my k1 is registering recent calls, not every call, but missed i can't see at all. many thanks
Hi there, what you need to do is go into your calls list, and delete all call history. So that should delete incoming, outgoing, missed calls, your call time etc. once you have done that then it should work
Jun 12, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Unable to delete Missed, Dialled And Received Call lists.
I think you should check the date/time setting and make sure that it is correct, then try to delete the call list again.
Feb 04, 2009 | Nokia 9300 Smartphone
Deleting missed call symbol
Hi you go to your answer button with is the green phone thingy. you press it ,as it opens it will show you the missed calls ,press on the missed call you received then you'll have the open button option. Just open it and the missed call red arrow ,should dissapear.
Dec 02, 2008 | Cell Phones
Sony Ericsson K610i mobile phone
I had the same problem... it was solved for me by going into
Menu -> Calls -> More -> Delete All
I think the problem was that the missed and other calls were stored in the provider's server... and deleting each entry from the list was not deleting them from there, but instead just deleting the entry from my phone.. anyway... now it saves and shows the missed calls.
I hope this helps...
Sep 24, 2007 | Sony Ericsson K610i Cellular Phone
Motorola Mobility H202 Cordless Phone Logo
19 people viewed this question
Top Motorola Mobility Lands Phones Experts
Motorola Mobility
Motorola Mobility
Ngoro
Ngoro
Beth
Beth
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
