Question about Philips HTS3450 System
Can not get any signal to tune? - Philips HTS3450 System
  • 2,071 Answers
Thats is a symptom of defected tuner that cannot tune a signal,open your unit look the tuner and resolder it maybe it is a cold solder or loose contact all parts joints only tuner section...
Posted on Jun 15, 2009
There is no signal on my emerson tv, how do i get one
1. You are not on the right input for the signaling device: Verify which input number (or type ie HDMI/component/video/Cable) your device is connecting to and tune to that input.
2. The signaling device is not powered on. Verify it is on and the cable is properly seated into device and TV.
3. The cable is bad. Try a different cable or use alternate type of connection.
4. The specific input port on the TV is bad. Move the connecting cable to a different port (ie from HDMI 1 to HDMI 2) and tune the TV to that input.
If you are using an Over the Air signal (OTA) with rabbit ears or and antenna use the TV menu to run an auto tuning scan of your local stations.
If you are using a tuning box (cable/satellite) over a coaxial connection check connections and tune the TV to CH 3 or CH 4 and check for picture. There may be a switch on the back of the box indicating CH 3 or CH 4.
Sep 18, 2017 | Emerson Televison & Video
I decided to re-tune all the channels. Now I have only half the channels. I have tried to re-tune, with the same results. Manual re-tuning will not accept the wanted channel numbers. Please help.
It could be a signal strength or signal quality problem - too strong a signal is as bad as a weak signal.
Retuning using a different aerial with a known performance would prove that. Once retuned with all channels present and stored in the memory you should find the original performance using your own aerial is restored.
Sep 08, 2017 | Televison & Video
Cannot get a signal and cannot tune device.
Sorry but with this limited information we can not assist
Sep 14, 2015 | Panasonic Computers & Internet
I have a sharp aquos LC32AF3x which was working fine . We have moved and now it will not tune into stations. I have used the same connections on another tv and that tv locates the stations when tuned but...
Your TV has to be able to sense local station signals as part of the tuning process. there may be a problem with the antenna or cable connection.
Jan 05, 2018 | Sharp Televison & Video
I have a quasar tv and Z remote how do i program it to my tv?
Tune the TV with the remote control provided with device
1. Power on the TV by pressing momentarily the power button
2.Select the menu option on the programs list on the remote
3.Using the navigation arrows to locate the channel options
4.The option of tune also indicated as auto tune is the function to select to program the TV
5.A press on the auto tune button would initaite a scan through the entire TV functionality,
6.The process should tune the TV in which time would acquire available signals either broadcasts or devices that have been connected to the TV would be recogsied as well.
7. Any TV broadcast signal would be stored in the TV memory making possible program broadcast after process is achieved.
Important note
The TV would only capture signals on subscription to broadcaster establishment. For example, after TV tune up, no shows available requires acquiring service from providers. Examples of which include Dish Network, Time Warner Cable, or Digital Subscriber stations for possible broadcast subscriptions
Dec 02, 2010 | Televison & Video
Tuning
U want to tune in free air tv?,not analoge signal anymore.All digital now,must have a good antena like digital antena,and a digital converter box.Or must have cable or setalite signal.Than can watch without a converter box.
Dec 18, 2009 | Televison & Video
Off freq on ssb TX.
.002 Mhz is really not that much off, try having them tune to your signal When I talked SSB I would have everybody tune to my signal.
Jun 09, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Cobra 29 delta tune
For normal operation, set this control to the center position.
This feature has several uses and can help receiver operation.
If a received signal is slightly off frequency, the Delta-Tune control can be used to òfine-tuneó your receiver. Fine tuning is accomplished by listening for a more readable signal at the speaker or by noting the Smeter reading when the Delta-Tune control is operated. Another use of this control is eliminating adjacent interference (bleed over from other channels). If an exceptionally high level signal from an adjacent channel is creating interference on the channel being used, the Delta-Tune can be used to minimize or eliminate the interference. Rotate the control until you obtain minimum adjacent channel interference. NOTE: Delta-Tune is operable only in the receive mode.
It doesn't actually help receive any better, just can help kinda like a clairifier.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
May 19, 2008 | Cobra 29 LTD CB Radio
Philips HTS3450 System Logo
52 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
