Question about Oki Electric Industry OKIDATA 62428701 C5550N MFP 120V AllInOne Laser Printer
Where to download oki c5600 hostif.exe?
Where can I download hostif.exe for oki c5600?
Strange clicking noise OKI C5600
it is not the toner it is the drum. just replace the drum and it will be fine. you may of noticed your printer has been printing a little streaky. i have had this problem with my c5600 and after i replaced the k drum (the noisy drum) it was fixed intill 4 months later when the blasted thing broke again
Jun 02, 2010 | OKI C5400 Laser Printer
OKI C5600 error code 411 says toner cartridge is empty (isn't)
Kedves Mindnyájatok!
AZ alábbi hibaüzenet jelenik MEG AZ OKI C5600dn kijelz?jén Minden szín? tonernél. Sot MEG AZ eredeti sárga-NAL van.
Chip cserével lehet orvosolni SEM a problémát. Eddigi javaslat volt: 4 db toner éS alaplap csere. Ennyiért pia con színes nyomtatót is lehetne mar venni. Tudnak segíteni? Van Valami praktikus javaslat a hibám orvoslására?
További Szép estét kívánok!
Lacika
Oct 26, 2009 | OKI C5650n LED Laser Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
How do i put paper in the bypass feed of the OKI C5600 printer? I can't find the bypass tray or how to put thicker paper through the machine.
The bypass feeder or multipurpose tray as OKI call it is situated above the standard or 1st cassete paper tray.
It is usually hidden. Ther is a door door with an handle. Pull the handle to open it and then extend the tray.
For images and instructions on how to feed the paper, check page 13 and following pages of the User Manual you can download from here:
http://www.c5600.co.uk/library/documents/c5600/C56uEN1.pdf
Also, I leave you the link to the support homepage for your copier. On the left side of the page there are several useful inks (to download drivers, software and documents, how-tos, explanation of errors, etc.):
http://www.c5600.co.uk/index.asp
Aug 19, 2009 | Ricoh Aficio 250 Copier
OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Apr 20, 2009 | OKI C5500n Printer
On Oki C5600 printer with error message " Order k drum" and does not let me print. Can any one help how to reset and clear this message?
Try this procedure, don't know if it will work on your models.
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
Apr 12, 2009 | OKI C5500n Printer
Toner warning
THE TONER CONTAIN NEED TO BE WASHED OUT WITH SPECAL CHEMICALS, PRINTS NEED MAINTNANCE, OVER FLOW CONTAINER MAY HAVE TO BE EMPTYED ALL SO, CORRORNA WIRES NEED TO BE CLEANED
DRUM MAY MAY NEED SERVICE ALSO
ROD
Feb 03, 2009 | OKI C5200n Laser Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
Hi oki c5600. printing A4 size labels succesfully until printing image with large areas of colour. "Smearing" gets progressivly worse as the doucuments goes through
that means that your ink and the label materials are not compatible. you may need to use less ink, or a more porous label facing.
Aug 20, 2008 | OKI Office Equipment & Supplies
Oki Electric Industry OKIDATA 62428701 C5550N MFP 120V AllInOne Laser Printer Logo
362 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
