Question about Vidalia 628
Ignitor replacement Cannot locate ignitor kit for Vidalia grill #628. Company will not answer email or phone calls. Any ideas where to get this replacement part?
Ignitor doesn't work on DCS grill
Just use a 9 volt batterie
Jan 20, 2018 | DCS Grilling
How to replace electric ignitor
Locate the current ignitor on your grill. Turn counter clockwise until you can remove from grill. Pull out AA battery and replace with new one. Repeat the first step except turn clockwise.
Jul 29, 2012 | Barbeques Galore 38" Grand Turbo built-in...
How do i remove the ignitors out of a charmglow grill model number 720 0036 HD 05?
The ignitor electrode(s) are held in place my a small tab that's attached next to each main burner with a small screw. To totally remove the ignitor electrode, disconnect the wire to it first, by pulling the wire's sleeve off the ignitor pin. Then unscrew the holder/tab. There should be no need to replace the wires, if you are just replacing the ignitor electrodes. Be sure to remove the battery from the Ignitor Module, before trying to remove the electrodes.
Apr 10, 2011 | Brinkmann Charmglow Stainless Steel LP...
How do i remove the battery on my char broil ignitor? thanks
This is kind of tough to explain without pictures, but here goes:
You may be able to just look on the underside of the ignitor and replace it or them without removal.
If not, behind the ignitor, on the other side of the panel it is mounted on, there is a round threaded part that holds the ignitor in place. You can (hopefully) use your fingers and just lefty-loosy that part off, releasing the ignitor. It will come out the front side of the plate it's mounted to easily, and you will see where the battery is located. Replace, and then just screw that threaded part back on tightly.
Hope this helps.
Jan 21, 2011 | Char-Broil 7000 Quick Set Gas Grill
Ignitor
Check out the product manual, if you need a new one you can download free at Char-Broil.com. Should be a simple fix. Any problems and you can contact the company, they are most helpful!
Jul 02, 2010 | Char-Broil CharBroil 4637318 Grill
Ignitor on performer grill stop working. Can
Call Weber at 800-466-1071 and order the ignitor kit: http://www.weber.com/publicSchematic/view.aspx?model=841004&Sequence=26&Suffix=
Aug 22, 2009 | Weber Performer Grill
Not enough gas through buners
it may be the regulator not sure but a easy fix
Jul 12, 2009 | Grilling
Vidalia 628 Logo
Top Vidalia Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Vidalia Grilling Expert? Answer questions, earn points and help others
