Question about Toshiba 35A44 35" TV
Toshiba 30 HI,I have a 30" Toshiba tv and when I plug it in nothing happens. The light on the front of the tv doesnt even come on. I was told it needed a off/on button but when I called a tv repair company they said it probably needs a fuse. I called another tv repair company and they said it probably needs a start up circuit. I have a friend who can work on the tv but he said I need to go on line and get a manual. I went on line to down load one but they didnt have my model for me to download. The model # is 35A44 serial #21376882 it was mfg 2/05 so it is not that old. Please let me know how to get a manual for this and let me know what you think is the problem with the tv, if you can without looking at it personally. It is about 35" from corner to corner, I guess that is how it is measured. Thank youD. Clark
  • Sagacious_a Dec 01, 2007
    I have the exact same problem and like you my tv is only a couple of years old. One day my Toshiba 35A44 was working fine the next day it was dead. It seems not to be receiving any power. I called the repair center and they told me to hold the power button in for five seconds but nothing happened; then they had me to unplug it and hold the power button in for 2 minutes but still nothing happened.
  • utcb32 Dec 20, 2007
    I have the same problem I have a 35a44 i pulled the back cover off and checked all fuses they were intact i was told it could be the coil next to the 10a fuse could this be true or are there any other solutions Thank You
  • 59 Answers
A fuse is fast and easy enough for you to try first
Posted on Oct 31, 2007
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Toshiba TP48E50 Projection TV - Power light blinking no sound or picture. All plugs are stable and power sources are good. Cable is on as are all other equipment. Remote is fine. Without picture or...
put your remote down and dont use it. disconnect the power at the plug. wait 30 secs. reconnect the power at the plug and use the ON button of the TV, see what happens. only then try remote. a TV is never OFF unless its power is disconnected even when the remote tells it to go off, its still in standby and what it needs is a proper OFF for a while.
Dec 20, 2017 | Toshiba Televison & Video
I have a large projection toshiba tv. When I turn it on the red light indicator blinks but tv screen does not go on. Please help and let me know what I am doing wrong. Thank you.
one thing you may try first is disconecting the tv from ac outlet and plug back in ater 20-30 seconds, try to power back on. If nothing happens you're not doing anything wrong it might be that the tv needs circuit repair, the light blinks and you get sound indicateds a possible deflection board problem either horiz out transistor or surrounding circuit if you only get the blinking light no pix or sound could be also indicator of defl circuit failure or switching mode power supply acting up.hope this helps please let this site know if your question was answered.
Aug 22, 2009 | Toshiba Televison & Video
My Zen Vision M 30GB mp3 player won't turn on, the blue light at the top flashes but the screen won't pop up, not even when i plug it in to charge it (which it usually does automatically). Now, i tried to...
Mine does the same thing, You just have to leave it plugged in for a long time, and after a while the black screen with the battery that tells you it's charging will show up.
Trust me, it'll happen.
Jul 20, 2009 | Creative Labs ZEN Vision:M Digital Media...
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Frigidaire Front load washer FTF2140FS
What is this a Speed Queen??? I need model & Serial Number.
May 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Mitsubishi wd 57731 wont power up
There is a lamp cover on the back that only requires a few screws to remove. the lamp is behine there, you will need a standard screwdriver to remove the lamp and inspect it. If indeed the lamp is bad you will see it shattered and/or burned at the tip. The timer light flashing for 30 seconds is normal as the TV is going thorugh a boot up process. One word of advise, don't touch the glass part of the lamp pnly the case.
Nov 26, 2007 | Mitsubishi WD-57731 57" Projection HDTV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Toshiba 35A44 35" TV Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
