Question about Poulan Pro 24-Inch 208cc LCT Gas Powered Two-Stage Snow Thrower With
Stalling surges and stalls out after 20-30 minutes of use. any ideas?
    Sergeant:
  • 416 Answers
Drain gas from carb and tank get some fresh non ethynol gas
while carb bowl is off spray/ clean with carb cleaner spray.
when you drain gas put it in clear container so you can see if there was water or dirt in it. helps to figure out the problem
Posted on Oct 29, 2014
Surging stalling
could be the tps the iac or the mass airflow i would try the iac first.
Sep 06, 2013 | Cars & Trucks
1992 LEXUS LS400 STALLS WHEN HOT & IDLE SURGING
Sounds like a fuel problem or a clogged catalytic converter. Check your filters for the fuel system. Make sure you can hear the fuel pump kick on. If that doesn't work you need to separate the header from the catalytic converter. Then try to stall it again. Hope this helps.
Jun 12, 2009 | IBM ThinkPad T30 2366 Notebook
Toro 20016 engine surges up and down - then stalls
You have carburetor problems. Chances are the diaphragm needs to be changed and the carb. needs a good cleaning. If you need tips on carb. cleaning, let me know.
Jim
May 28, 2009 | Toro Lawn Mower With Toro Power Tools
Continous surging and stalling
Per your description, I would suspect a fuel pump issue. When the fuel pump is running the pump impeller heats up. On an older pump the impeller can begin to seize up and momentarily stops and starts. Some times it just stops and has to cool down for a couple of minutes, then is ok for a while.
To test this theory, when the engine stalls and stops, your mechanic can use a rubber mallet and hit the bottom of the gas tank, this will free the pump impeller and the car will start again.
Or, have him install a fuel pressure gauge and go for a drive. If the pressure begins to fluctuate and drop, you know the pump is causing the issue.
Good luck, let me know.
Regards,
Apr 30, 2009 | 1990 Buick Reatta
My car surges some times
Follow this procedure for these kinds of problems.
Here is the most common cause of surges and stalls and low idle, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Jan 10, 2009 | 1991 Ford Escort
My car surges after running for 10 minutes when I put it in parking or drive can you tell what is wrong .
Nov 05, 2008 | 1991 Ford Escort
Car petrol engine revolution surges.
Here is the most common cause of surges and stalls, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Oct 28, 2008 | 2004 Isuzu Rodeo
Poulan Pro 24-Inch 208cc LCT Gas Powered Two-Stage Snow Thrower With Logo
142 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
