Question about Yamaha Electrical Supplies
Will not stay running
Starts but wont stay running
My 1999 audi car i start it and it and it wont stay running it konks out
Vacuum or incorrect air fuel ratio .also if you moved the butterfly inside the throttle body you will need a throttle position sensor .
Sep 27, 2014 | Cars & Trucks
95 explorer wont stay running
Someone will need to check the key switch and figure out what is not getting power. Could be the key switch or a relay.
Jun 08, 2013 | Cars & Trucks
1990 Ford F150 wont stay running, replce ECT and ICM ... still wont run. Water coming out of exhaust after trying to run. 5.0 w/5-speed.
Very possible bad head gasket and fowled out plugs and/or O2 sensors. Remove spark plugs and check condition of them and pull O2 sensor to see if it is green from antifreeze. Good luck.
Feb 13, 2011 | 1990 Ford F150
I have a 1992 ford probe 2.2 that wont stay running
try a compression test on the cylnders, If it overheated when the head blew , the rings can go soft with too much heat
Apr 24, 2010 | 1996 Ford Probe
The car wont stay running when in the run possion
OK lets start with this..
I am guessing that when you say possion you are meaning you gear selector and when you put it in say drive.
If that is the case.....
Your problem is most likely the fuel pump relay or fuel pump itself.
Start with checking, or have it checked, the fuel pressure at the fuel rail.
If the pressure is low then a fuel pump can be suspect. There are then other test which have to be performed to see where the exact problem is.
Sep 16, 2009 | 1986 Ford Tempo
Car wont stay running after initial start up?
Will it stay running if you keep the pedal depressed. If so you have a Idle Air Control valve issue. If it wont run at all it may be a bad fuel pump
Jul 14, 2009 | 1991 Chrysler Imperial
I have a 1988 GMC Sierra 1500 thast wont stay running
Use a gage and check proper fuel pressure. With tbi fuel injection, the fuel pressure is 9--13 psi. I have seen fuel injector spray pattern that looked good to me, but, the fuel pressure was half of what it should have been. 5 psi may show a good spray pattern, but, it won't start and run a v8. In my opinion.
Any applicable trouble codes? Your obd1, you should be able to check some codes yourself, if there are any.
Apr 21, 2017 | 1988 GMC C1500
Wont start
if i drive my bronco to work shut it off it wont start sounds like it has a dead battery if i let it sit for an hour it will start back up can you tell me if you know what it is
Dec 15, 2008 | 1989 Ford Bronco
Electrical Supplies Logo
42 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
