Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
I have a Dlink Modem, want to setup a home network.
Hi, I have a Dlink switch. I want to make a home network. I have given 192.168.1.2 to one PC and 192.168.1.2 to ohter. Both have subnet 255.255.255.0 as subnet and 192.168.1.1 as default gateway.Also my modem has 192.168.1.1 as IP. My PCs cant ping each other.
Need Help ASAP.
    Scholar:
  • 59 Answers
Each network node needs to have a unique IP address try changing one of the PC's to 192.168.1.3 (it's it's not being used by another node)
Posted on Jun 15, 2009
The wireless indicator wont light up so i cant go wireless ?
Hi Desmond
This does not appear to be an actual question!
You actually made a statement.
You need to find the IP address for your modem (e.g. 192.168.1.1) Use your Browser to gain access to this address, By typing in the IP adrs into the URL space at the top of the browser window.
Supply the modem password required for your home modem.
Then you have access to change settings to turn on the WiFi section. Change it's channel (1 to 13) and set the wifi password.
Cheers
Setting up Wireless Network with Access Point Dlink and Modem ADSL
How to Configure the Modem Router
How to Setup An Airport Extreme
Sep 14, 2016 | Computers & Internet
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Lenovo S series ideapad will find my dlink router no network addr
u need to setup a network with windows set up a home or office network then windows will configure the network address and assign the address.
Jul 09, 2009 | Lenovo IdeaPad S10 - 42312BU Notebook
Hi i hav purchased a Dlink dir 300 router. is this router capable of letting multiple pcs n cell phones connect to it for internet wirelessly with out the need of keeping 1 pc switched on all the time? i...
Yes if you consult the manual that came with the router it will show you how to connect the modem to it and setup the DSL (PPPOE)settings. Some Modems though already have the PPPOE settings within the unit and then the router would just need to be set to automatic. You will need to configure from the PC but afterwards you can shut down all your PC's on the network at anytime.
Jun 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use 192.168.0.1 as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as 10.150.1.1 for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Feb 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Open Port 81 on Netgear Switch
Actually you need to open the port on the cable modem / router. Switches just pass the packets along.
May 20, 2008 | Computers & Internet
DLINK SWITCH DES-1008D
other units cant connect to my installed port hub and were having hight mare connecting it
Apr 09, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
283 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
