Question about Mr. Coffee TFTX85 Coffee Maker
Cold coffee pot will not stay on
The light and machine stay on when it's plugged in
if you've tried to turn the switch off and the coffee pot stays on the then the switch needs to be replaced or you'll have to get a new coffee pot
Mar 09, 2016 | Coffee Makers & Espresso Machines
Fagor cr-22 is not working and showing 3 flashing lights alternatively left and right? what is the problem
you should always use just about one tablespoon of white vinegar added to a potful of cold water, poured into your coffee maker, followed by one full pot of plain cold water to rinse thoroughly.....I think using at least 2-3 full pots of cold water to rinse should fix the problem. Of course you realize you have to have the pot on each time you pass water through it, as if you were making coffee. I think calcium cleaaners are too harsh otherwise. destinie1106@gmail.com
Feb 18, 2012 | Fagor Coffee Makers & Espresso Machines
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
What makes a perculator heat?
Hi, If you have a Farberware, Just look into the bottom of the pot. There you will see what looks like a hole in the pot. That is the high heating element, under the pot, when you go to make coffee the pump ( rod) sits into the hole. When you turn it on to make coffee the high heating element that the pump is in gets very hot and starts pushing the water that is in the hole to the top (that is called perking) the hot water goes over the the top and the drops into the coffee, This keeps going on until the thermostat feels it has reached 190 degrees or close to it and turns the high element off. While this is running it's cycle the keep warn is on helping the water to get hot, when the main element is off the keep warm element that runs around the bottom of the pot stays on all the time the pot is plugged in. Should the coffee get to cold the thermostat will turn the main heating element back on until it is back to 190. This system was developed by Farberware and a lot of makers copied it, But Farberware sold the pots and was known for a FAST and HOT cup of coffee. Farberware started making them in China and the pots are having a hard time keeping it up to American standers, and parts are very scarce.Farberware USA pots have been around a long,long time and are still going strong . I hope this helped you to understand how the pot works.
Dec 09, 2010 | Faberware 12-55 Cup Coffee Urn
I haveBX-B . I had the pot set up for me to push the on button for Monday Morning, but the water ran throug and it was not on.So now I have cold coffee in the Decanter.
The Bunn coffee maker does not operate as most coffee makes do. You cannot leave the Bunn in the off position and then just flip the switch to on and pour the water in. You will always get cold coffee if you do this. It takes time for it to heat the water. The On/Off switch should be left in the On position all the time. This keeps the water hot in the tank, thus providing hot water when you need to make coffee. You then just pour the cold water in the top, shut the lid, and have a pot of coffee in 3 minutes. The On/Off switch is a vacation switch, and you use it only when you are not going to use the coffee maker for a couple of days. Older Bunn coffee makers did not even have an On/Off button. You simply unplugged them when going on vacation. So turn the switch to the On position and leave it there. The unit will then work as designed. Forget how other coffee makers work, this is a Bunn and it is the fastest coffee maker you can buy and must be left on all the time. that way the water stays hot and the unit will keep it that way.
Nov 16, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Coffee has a greasy taste
You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
Have a cup on old saw
Aug 09, 2009 | Bunn VPR Coffee Maker
My stay or go coffee maker. When I try to make a full pot of coffee I only get half a pot I push it on again and still only get a little bit more coffee. I have to start up about 4 times to get a full pot.
Try cleaning out the water system, it may need to be descaled, buy the descaler from the supermarket, follow instructions, make sure machine is well flushed out with clean water after cleaning operation.
Jul 07, 2009 | Hamilton Beach Stay or Go 45234 Coffee...
Coffee maker wont stay on after making a pot of coffee help
i downloaded the owners manual at http://www.cuisinartwebstore.com/detail/CUI+DGB-300BK
and resolved it by reading the manual. ( i had lost my original )
May 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Heating Element Shuts Off Very Early
Reset the timer for shutting off the hot plate, instructions are in the user manual.
Jan 31, 2009 | Cuisinart DGB-300 Coffee Maker
Braun Proaroma coffe pot wouldn't brew
I found on online operater's manual for this coffee pot and solved the problem.
Aug 21, 2008 | Braun Aromaster KF 12 Coffee Maker
Mr. Coffee TFTX85 Coffee Maker Logo
22 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Jim London
Jim London
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
