Question about Samsung Washing Machines
Thermistor replaced the thermistor and it still wont work
My stand alone Kenmore elite 3 cycle under counter ice maker has stopped making ice. is there a reset procedure?
This is what I read somewhere....
ok, then this means that one of your thermistors is shorted. There is a chill plate thermistor mounted to the bottom of your silver plate where the ice is formed, and there is a white thermistor mounted to the right side wall inside your bin. You can disconnect the chill plate thermistor and run a cycle to see if it will run without being connected. If the error goes away, you can leave the thermistor disconnected or replace it, either way the unit will continue to work.
If you disconnect the chill plate thermistor and it still doesn't work, then you need to replace your bin thermistor, you can't just disconnect this thermistor to get the unit working again.
May 02, 2016 | Kenmore Refrigerators
Dometic rm2652 wont cool but has power and gas
disconnect thermistor run overnite if ok replace thermistor if not ok replace cooling unit
Jan 13, 2014 | Dometic RM2652 Refrigerator
Refrigerator wont work on gas or electric
disconnect thermistor let run if ok replace thermistor if not bad board or cooling unit
Apr 06, 2013 | Dometic RM2852 Refrigerator
Damper wont open
send the model number and also did you change the mother board in the back of the fridge,wr55x10942,check out this picture of the board,it tells you how to read out the damper,thermistors,defrost parts
http://www.flickr.com/photos/zenzoidman/4482598198/sizes/o/in/photostream/also check this out if you can't find your tech sheet down where the front kick panel is
http://fixitnow.com/wp/2010/01/17/ge-profile-pss25-refrigerator-freezing-everything-in-the-fresh-food-compartment-regardless-of-temperature-setting-and-the-water-dispenser-quit-working-too/
Jul 11, 2012 | GE Refrigerators
Minimax NT Heater: Heater wont light Err error code. Reset and nothin...
You should try changing out the thermistor first. That is the likely culprit. Not too bad of a repair. The main pcb could also cause this, but i would r and r the thermistor first. HTH
May 17, 2010 | Pentair Minimax NT Heater
Indesit 1200 series wont work.
F03 indicates that the wash thermistor is open or short circuit, the thermistor is part of the heater element. you need to test the heater and thermistor, and possibly replace.
Indesit recommend that you call an engineer, but it can be done by some one who is competent enough.
Unplug before you do anything to it.
Plz leave feedback.
Thanks
Dec 10, 2008 | Indesit W 123 Front Load Washer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Wont work
simply you just replace thermistor in order to activate your unit.
May 19, 2008 | Hitachi RAS-09UH Air Conditioner
Dryer
Error codes. are any of these lit? PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Kenmore 82836 Gas Dryer
Washing Machines Logo
15 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
