Question about British Telecom Lands Phones
BT6500 base not ringing
2 Suggested Answers
  • 29 Answers
SOURCE: How do i extend the rings before the answer machine cuts in on my BT6500
Set the answer delay
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press (Calls) until Settings is displayed, press Select.
3.Press (Calls) to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use < or > to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Set the maximum message length
You can set the maximum length that an answer
machine message can be: 1 minute, 2 minutes or 3
minutes. The default setting is 3 minutes.
Select.
3. Press (Calls) to highlight Ans. & record and press
Select.
4. Press (Calls) to display Max. msg length and then
press < or > to select the length you want and
Billy from Hayward
It is in the owners handbook page 45 get it while the link last
http://www.shop.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
Posted on Jan 09, 2015
Tried taking batteries out switching off the phones and still not receiving all in coming calls our phones are bt6500 please help
These phones are designed to at least silence some "spam" phone calls. You should be able to alter some settings. You can reset the phone so that it and its answering machine capabilities return to the factory defaults. http://www.manualslib.com/manual/713422/Bt-Bt6500.html?page=60
The following quick setup guide on page 8 refers to how to block certain calls. Your phone may have been setup in such a way that it is blocking some desired calls. I suspect a return to factory defaults will remove that problem and then you will have to experiment or contact the phone's support to find out how to block what you do not want otherwise. http://www.businessdirect.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
I suspect you bought this from a specialist business that should be able to offer guidance.
Feb 04, 2015 | Cell Phones
Select.
Select.
Select.
Billy from Hayward
Jan 09, 2015 | Lands Phones
How can I change no. of ringing tone in my BT6500 cordless telephone from existing 3 times to 8 times.
Pages 56 to 58 of your manual should give you the answer if you don't have the manual its available as a download here https://www.shop.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
Hope this helps
Jan 06, 2015 | Lands Phones
Re phone BT6500, how does one increase the number of rings before it goes to answerphone?
Hi
I give below the step by step procedure for changing the number of rings the phone will sound.
Select.
2. Press until Settings is displayed, press Select.
3. Press to highlight either Ans. & record or
4. Answer delay is displayed, use or to display
Be aware though that the number of rings needs to be less than your ansaphone service, for BT 1571 this is 5 rings, although more may be possible if you can get BT to change their 1571 for your line.
For more information about your phone you can download a pdf format manual from here:
https://www.shop.bt.com/content/uni2/documentation/8h3j/bt6500_user_guide.pdf
This can be saved to hard disk for future reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Honeywell DOLPHIN 6500:5300SR IMGR/28KY...
Purchased BT6500 Phones line crackled and breaks up
same problem - almost impossible to have a clear conversation. Have changed filters/moved the base several times - all to no avail. Sorry I ever changed phones from my philips which worked fine. anyone have something new to suggest as a solution apart from dumping the BT system?????????????
Apr 15, 2013 | Lands Phones
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
Lands Phones Logo
16 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
David Burbee
David Burbee
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
