Question about Sony Audio Players & Recorders
Poor sound when switching to both a&b speakers
I have a sony STR-D911 receiver and when I switch the sound settings from using just one speaker (a or b) the quality of sound and loudness drops significantly. I have it set to "dance" on the sound field. I have DBFB on. Any help works thank you!
  • 41 Answers
Check your speaker polarity. Make sure the plus and minus of all 4 speakers are the same, otherwise they will cancel its other out.
Posted on Apr 05, 2014
Sony STR-DG710 center speaker makes no sound. Connections are good.
Sometimes these units have the ability to switch the speaker off and on. Look up the speaker settings in the manual.
As each channel in the unit will be separately driven the power amp for the center channel could have failed, but I think it's unlikely unless you have had problems with the sound on it before, or connected it wrongly causing a fault.
Dec 16, 2016 | Sony STR-DG710 Receiver
Sony str-de185 left channel very scratchy and poor; not speaker, wire, or connections
Could be an open resistor in the amp for that channel. Might have to have a pro look at it.
Mar 26, 2013 | Sony STR-DE185 Receiver
My system is set up with an A & B (inside and outside) front side along with back speakers and a center speaker (for dialog on TV & movies) the center chanel does not turn off when you switch from...
Only the front speakers are affected by the A/B switch.Press the 2CH/A. DIRECT button on the remote to force the receiver to only output sound to the front speakers and mute the other speakers that are not being used.
Apr 02, 2011 | Sony STR-DG820 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
I have the sony: STR-DE 685. The sound in the
This sounds like a very poor connection. Please make a new splice on speaker and receiver. This should take care of this for you.
Feb 26, 2010 | Sony STR-DE597 Receiver
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Sony STR-SE501 makes popping sound/cuts off
just repaired my se 501 poor solder conections on blue rleays by speaker jacks,also blown center speaker seems there are 2 in it one blew and so did cpacitor running now just hooked up one in center speaker sonds great also stay at 8 ohms setting
Mar 17, 2009 | Sony Audio Players & Recorders
No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
Sony str-de875 amp. one speaker louder than the rest
hi. i have a sony amplifier. i plug the speakers in like normal. i turn it on and the right side speeker works fine. but you half to crank it up all the way just to barely hear the left speeker. we switched speakers and its still the same effect. we think its the amp itself. we tried our balance settings. it was fine. but right now its just playing one speaker louder then the left one. can anyone help me?
Apr 03, 2008 | Sony STR-DE875 Receiver
47 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
