Question about Canon DR-7580
Line down middle of paper
Cleaned lense, still putting line down middle of paper
    New Friend:
  • 78 Answers
Sounds like you have a scratched lens. If you have another unit, try replacing the lens from that one. If you do not, you will need to replace the complete unit or see if you can find one on Ebay.
Posted on Aug 19, 2014
How do I get in there safely to clean the mirror?? what do i unscrew first etc.. it still working just fine but the color is going after 15 years and i need to clean the inside.
Hello.
I would not recommend you to touch the mirror. It is hanged sort of reflection surface facing down so it is not real dust collector. You can clean lenses of your CRT tubes (red, green and blue) to improve your picture. Just remove rear cover taking out black and golden screws and you will see dusty lenses right away in the middle of the TV. Use DRY "Bounty" paper towels to remove dust from lenses, don't wet it with any solutions or it will leave film on optics. Just in circular motion move dust to the black plastic edges of lenses. Don't worry about some specs of dust that inevitable will be left behind - they will not affect image at all like thick layer of dust do.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi VS-6041 60" Rear Projection...
I get vertical lines running down the middle of paper
lift the lid ull see a thin **** glass make sure its very very clean
Mar 30, 2010 | Sharp AL 1631 Copier
Wide black lines down the paper. I have changed
Have you changed the Drum unit. Also there is a cleaning pad that you slide across the corona for cleaning. If you leave it in the middle it will give a black line, should be moved all the way to one side.
Nov 18, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
Have black smudge line in middle of paper have new toner and drum
Try taking out your toners, and on the drum you will see a green button which you can slide from side to side (it's on each of the colored slots). Make sure you put the the white plastic cover up and then it will slide. I hope this will help you.
Jul 27, 2009 | Brother HL 5250DN Laser Printer
Black Line down middle
The line is from ink coming up from the absorber pads on the bottom. It needs a good cleaning and a mylar sheet to keep the ink from coming up onto the rollers. A shop repair.
Jul 02, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Black line down middle of page
Clean off the glass place where the paper passes when you fax. You'll probably find some foreign matter on it. Wipe it off and you should be good to go.
May 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Light lines down middle when printing black
try to clean the class of the machine, if its still there, this means the black drum is scratched since its fine with other colors, to test it very good open the document feeder(put it up) and hit start buttom(without putting anypaper on class), black paper will come out, check if the line there, if yeah, change the black drum.
let me know wat happen Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Apr 24, 2009 | Samsung CLX 3160fn All-In-One Printer
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
BLACK LINE IN MIDDLE OF PAPER
Open the doc feeder and clean the scanner glass.
Minolta EP 2010 copier, top loading doesn't pull paper
Hello sir; try to made 2 copies one go through by adf another one just put on the glass,if one copyclean another not clean then clean up the glass, if both copy all lines then replace drum unit.
Jan 06, 2009 | Office Equipment & Supplies
62 people viewed this question
old marine
old marine
