Question about Protex Safe LC-53D Electronic Wall Safe
Cant open wall safe door battery dead
Safe door wont open due to battery very low or dead it is a LC wall safe
How to open doors on 2000chevy malibu battery dead?
The outside door locks/trunk lock will most likely not work due to the key not being able to be inserted/turned in the lock cylinder due to lack of use. Spray WD40 into door lock cylinder using supplied straw and insert key until it goes all the way in using sawing motion. If lock cylinder still will not turn continue sawing motion with key while holding gentle turning pressure on the key. This will usually free up any sticky/seized lock cylinder wafers and allow the cylinder to turn
Nov 29, 2015 | Cars & Trucks
My Elsafe battery died (S30-705) and I can't open it! I wasn't given any type of key or anything!!!
You need someone to connect an Elsafe Servicing Unit to supply external battery power via the connection cable to power up the device so that you can unlock the safe. The servicing unit attaches to a 9 volt battery to rescue failed safes due to battery problem. Once the safe is open, you can replace the safe's dead batteries.
Option 2: Get someone to drill the safe open.
Jul 08, 2015 | Home Security
How do I open my Sentry Safe when the batteries have gone dead?
Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
Oct 03, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
Dead battery cant open doors
Unlock the rear door and climb in that way or call a locksmith to open the door for you
Apr 13, 2014 | 2011 Toyota RAV4
you may be able to hook up a jumper wire to the starter post from under the engine compartment using a jumper battery.
Feb 01, 2014 | Honda Cars & Trucks
Low batteries in my safemark safe- how do i open?
e-bar is not a battery problem, it means the door lock is jammed, either use a rubber malet or your balled up fist and after inputting the code to unlock hit the door of the safe all around the key pad as hard a you can, your will hear the rods moving and unlocking the door. Hope this helps. I know it works I do this at the hotel I work in.
Jun 08, 2012 | Safe International Home Security
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
My 03 x type jag wont even try to turn over? Dash lights are fine but windows, mirrors and starter dead! All the dash lights and monitor and radio work but wont even tryto start? Transmittion wont come out...
Sounds like all of the high drain devices are disabled due to a weak battery. You are still getting dash lights and radio because they are very low drain devices. Try charging the battery to test for now. It could be a failing battery, or your alternator and or voltage regulator could be going out and not charging the system. But first, try to charge the battery, and see if you can start it, if you can, let it run for at least 10 minutes. If your alternator/VR is going out or is already out, you should have a guage, or idiot light telling you that you have low voltage. If its a light, you should see a red battery lit up on the dash, if its a guage, it should be directly in the middle +/- a little. If you are able to run the vehicle for a while with no light coming on, or guage showing low voltage, its safe to say you drained the battery, or it is failing. If its a few years old or more, i'd go ahead and replace it. Hope this helps :)
Sep 17, 2009 | 2003 Jaguar X-Type
My batteries dead and cant get in car to jump it security
Hi, you can go threw your fender wall by taking a few screws off and removing it. your batt should be sitting on top of your right side fender wall. you can run cables to the batt this way to charge it. you will have to remove the tire to access the fonder wall.
Jan 28, 2009 | 2005 Chrysler 300
Protex Safe LC-53D Electronic Wall Safe Logo
Top Protex Safe Home Security Experts
Lawrence Oravetz
Are you a Protex Safe Home Security Expert? Answer questions, earn points and help others
