Question about Steve Silver Granite Bello Counter Parsons Chair in Black
Parts number for granite bello black counter parson chair
Rear legs are shorter than the rest
Caple integrated dryer
I have seen some terrible installations in the field. If the granite was installed after the dryer, there is the possibility of the granite resting directly on the dry or possibly glued to it. You mentioned having lowered the legs, so I believe you meant the front legs since the rears are not accessible. I would take 2 wire coat hangers and put one around each leg. Then you can pull on them "wiggling" the unit left and right, up and down, while someone is also pulling at the top INSIDE of dryer door opening (drum).
If you are able to get this thing out, make sure you make all necessary corrections to the install.
Good luck.
Feb 11, 2014 | Dryers
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
How can I make my kitchen chairs shorter?
Shortening chairs is a very delicate process but can be doneif you have the right tools. You can usean electric sander to shave off length, one leg at a time. Once you are satisfied that they legs are allthe same length, you can cover them with protective pads.
May 29, 2012 | Furniture
We are installing a dishwasher--have it hooked up but can't seem to get the leveling legs loose so we can adjust the height. Also, the anchoring peices of metal stick out farther than our countertop.
Hello, This dishwasher has the ability to be mounted to the cabinets on either side of the dishwasher.the mounting brackets can be moved to each side. If it must be mounted to the counter top, the mounting tabs can be bent by hand and it will break the front part of the mounting tab. This will shorten the mounting bracket. If you have granite counter tops do not attempt to drill into to the granite counter call a granite fabicator. The leveling feet are hexagon shaped at the top of the of the leveling leg. Remove the front lower toe kick panel. This will allow access to the top of the leveling legs,then use a small cresent wrench or a socket and rachet.Hope this helps.Joe Connolly
Sep 18, 2011 | Frigidaire FGHD2433K 24 in Builtin...
I have a quantum 6000 chair and whenever I need to raise my chair for a period of time, my legs just dangle and begin hurting. Any suggestions or solutions for a temporary foot rest while my chair is...
Jal Check with your provider and ask them for a pair of Elevated Leg rests for your chair. They might have to install the holders for the leg rests but that is an easy job. And they are fairly inexpensive and can be put on and taken off easily. Hope this helps you
Nov 12, 2010 | Pride Mobility Products Quantum Jazzy 500...
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
Granite installation didn't get flush with slide-in range
suspect your contractor didn't allow for the tiled floor. the range legs are usually adjustable up and down. have you checked this?
Sep 04, 2008 | Cooktops
Steve Silver Granite Bello Counter Parsons Chair in Black Logo
85 people viewed this question
Top Steve Silver Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Steve Silver Furniture Expert? Answer questions, earn points and help others
