Question about Panasonic CF30 Notebook
Replace palm rest on a cf-30
Replace palm rest
How to replace the palm rest on a VGN-AW21XY
IF you can find the replacement part, which is most unlikely, you would have to partially disassemble your laptop to replace the palm rest after you remove the keyboard itself. There do NOT seem to be any videos online to assist with this in the US and only service shops in the UK.
Feb 10, 2015 | Computers & Internet
How do i connect cf-30 to tv with hdmi cable
The CF-30 does NOT have an HDMI interface.
The easiest way to hook to TV is by VGA Cable.
Make sure the CF-30 is turned off.
Attach the VGA cable to both the CF-30 and TV.
Power on the TV first.
Then power on the CF-30.
Voila, the video signal should display on the TV.
Make sure "source" on TV is set to PC.
Good Luck
Feb 13, 2013 | Panasonic Computers & Internet
Humidifier what does CF stand for
It may mean "Change Filter." After you replace the filter, unplug the humidifier for 30 seconds, and then you plug it back in, the CF code should be gone.
Dec 04, 2011 | Kenmore 14410 Humidifier
How to change the keyboard on dell studio xps 1645
You have to remove the palm rest ( the top part that has the keyboard and touch pad) to access the 13 screws securing the keyboard and shield which are underneath the palm rest. This involves removing the bottom access cover, rear caps, remove ten screws that are marked with a small P on base of computer. Remove two screws that are marked with a K. Remove two flat-head screws in the battery compartment. Then flip the system over. Remove the two screws at the top of the palm rest. Pry the palm rest loose with your fingertips, starting at one edge. Flip open the latch on the keyboard ribbon cable connector, and remove the cable. Lift the latch on the touchpad ribbon cable connector, and remove the cable. Remove the palm rest.
Feb 15, 2011 | Dell Studio XPS 1645 Laptop
1,2,4 hasselblad cft* 80mm speeds runs like 1/30
Those speeds tend to hang up from lack of use. You can try exercising them by cycling through the speeds, but it will most likely need service. The lubrication on the gear train has probably dried up, it is a common problem since those speeds aren't normally used.
Sep 28, 2008 | Hasselblad Cameras
Palm Lifedrive failure
I found this on the Palm website about the frozen Palm Logo screen
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=97,E=0000000000825271086,K=7324,Sxi=2,Case=Obj(26419)
Dec 03, 2007 | Palm LifeDrive Handheld
My Lifedrive won't boot up
Seems the LifeDrive Micro Drive is the killer on these Palms. Mine did the same thing and after extensive online research I found that the micro drive can be replaced with a Compact Flash card which is much more reliable. Apparently there are only certain CF cards that work with the LifeDrive though. I have found at least one retailer that sells a compatible CF preloaded with the Lifedrive software. The route I took for repair was to send it out to a guy that advertises his service on eBay. You send in the LifeDrive, he diagnoses it for $5, and can install the CF card with software for $89 (he waives the $5 if you have him fix it). I am looking forward to getting mine back in permanent working order! Here is the link:
http://myworld.ebay.com/itsnothere/
Oct 14, 2007 | Palm LifeDrive Mobile Manager Handheld
Panasonic CF30 Notebook Logo
19 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
