Codi 4-Digit Combination Cable Lock - security cable lock Logo
A
Anonymous Posted on Mar 27, 2014
Need to set combo on CODi cable lock
Codi lock set
Okay I have a 1990 Acura integra gs hatchback. When I first crank it up its fine then when I go it cuts out and spits and sputtered and almost stalls. And acts like it starves for fuel. But when I push...
Yo, Codi. Your problem is a bad EGR diaphragm. It's a bad vacuum leak making it do what you've explained. Replace the Exhaust Gas Recirculation (EGR) valve and this won't happen any more. Good power on demand.
138helpful
10answers
How to reset nokia 701 security code
my nokia 701 forget security code
Mar 31, 2012 • Cell Phones
Where can I get drivers for the Codi OPJM USB/PS2 Optical Mouse? Not on Codi.com.
Q: What operating systems are CODi's accessories compatible with?
A: CODi's accessories are typically plug and play and are compatible with most operating systems, including Windows 2000, XP and Vista; Mac OS 10.x and Linux 4.0 Kernel and above. If your operating system is not listed above, please call customer service at 1-800-CODIINC or email our customer service team at [email protected].
I suspected this to be the case, but the mouse should be plug and play supported. Most operating systems have the proper drivers included and your computer should recognize it. If it doesn't, contact their customer service.
Good Luck,
Mark
Mouse not responding to movement or clicking
check the other end of remote usb that is attached to computer ,unplug and plug again .and wait for OS to install it properly
if it works do vote
Mouse is on and nano receiver is connected, but computer does not react to it.
try to find a small button on the receiver and the mouse. press the button on receiver first then press the one on the mouse
I have a ws-55809 and the power turns on then turns off and error codi 2 2 so can you help me
2-2 is a short protect, meaning one of the low voltage supplies is out of reference range. The most common cause of this is a convergence IC causing a load on the + or - 24v line. You need to replace the IC units. Cost per unit is about $19.99 you need two plus labor.
Top Codi Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Codi Lock and Locksmithing Expert? Answer questions, earn points and help others
