Question about JVC XL-R5000BK CD Player
Can't unlock recorder tray
Display won't work ,cd recorder tray locked?
Need to unlock din lock
By 'Unlock din', do you mean unlock the region the recorder uses, unlock the din input or unlock the tray or what?
When recording and you see 'unlocked', it means the DIGITAL signal you are trying to record is unclear or missing.
If you are trying to record a signal from another region disc, it will not copy. Add a little detail.
Feb 21, 2012 | Pioneer PD-R609 CD Recorder
Rdr-dc100 locked
The child lock is on. Press the power off until just the time shows in the display. Then press and hold the stop button until the display shows "unlocked". You should be able to open the tray now.
Feb 19, 2012 | Sony Televison & Video
"tray locked" message
Hi
There must be a unlocking button on your remote or player.(Child proof) unlocking code might be needed.
Check the owners manual or do a web search for more info.
Regards
Phillip
Oct 16, 2009 | Philips MX5060D System
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Sep 18, 2007 | Philips CDR795 2-Disc CD Recorder
Trays locked
remove the tray out & put the grease on gears under the tray
Apr 01, 2007 | Philips CDR795 2-Disc CD Recorder
Trays locked
Hi, I had the same problem and i found out that if you hold down the fast forward and the rewind buttons with the power on and off button it will reset. It took me a couple of goes but after a while it worked. When you do it keep all of the buttons held down and a series of numbers flash for about a minute then it will reset. Good luck, Jeff.
Nov 15, 2006 | Philips CDR796 2-Disc CD Recorder
Locked Cd Tray
The solution is to turn the machine onto standy and then hold the 'display' button for a few seconds, and voila, the trays are unlocked... geni-arse!
Aug 05, 2006 | Philips MC-90 CD Shelf System
JVC XL-R5000BK CD Player Logo
37 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
