Question about Samsung Dryers
Samsung dryer won't turn on
Not the house fuse, but our dryer will not turn on at all. what is the reason?
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
No heat when drying
see this causes and fix it. God bless you
Power From The House
Door Switch
Wiring
Sep 27, 2012 | Dryers
Maytag Neptune dryer was always drying on high heat, now won't turn on
Door Switch
Wiring
Sep 27, 2012 | Maytag Dryers
Unit runs, not drying clothes completely
Door Switch
Wiring
Sep 24, 2012 | LG DLE0442 Electric Dryer
Samsung DV338aew does not get hot
I just took the front panel off of my Samsung dryer the belt is off. If you take the front panel off you won't believe what you will see it's so much dust... from all the clothes drying. Did you tried to take the front panel off? First turn off the switch to the dryer at the fuse box so there will be no power in there while you vacuum it out. As soon as I can put the belt on I will vacuum it thoroughly. I'm sure that is the reason why it the temp... is not hot enough.
Good luck.
Erika
Aug 12, 2012 | Samsung DV218AEW Electric Dryer
Maytag dryer mde308dayw won't turn on
The most probable thing thats wrong causing the dryer to not start is going to be a blown thermal fuse,when it goes out it cuts power to the motor circuit...do you have a display on the front yet it wont start???? or no display??
If you do have a display yet the dryer wont start it very likely will be the thermal fuse,it fits into the blower housing below where the lint filter fits into inside of the door,or depending on your model it will be in the rear but in any case it will be in the blower housing below where the lint filter fits all be it in the front or rear, To access it to check it remove the small lower front panel or the rear panel if it comes off(if not its going to be in the front) and it will be on the top of the blower housing,to check it measure it for continuity (ohm it out) with zero ohms resistiance.
This is what it looks like in the pictures below,either one of these two styles.
If that turns out to be the problem be sure to take apart the blower asm. and clean all lint from it and also check the venting from the back of the dryer all the way to where it exits the house....since the usual reason the thermal fuse goes out is because of poor airflow because of built up lint/blocked vent.
GENE
Ads by Google' + // // '' + // '' + // makeBoldAdWords(google_ads[0].line1) + '' + // // '' + // makeBoldAdWords(google_ads[0].line2) + ' ' + // makeBoldAdWords(google_ads[0].line3) + // '
' + // google_ads[0].visible_url + ' ' + // '
' + // ''; // } // else if (google_ads.length > 1) if (google_ads.length > 0) { s += 'Ads by Google'; /* * For text ads, append each ad to the string. */ for(i = 0; i ' + makeBoldAdWords(google_ads[i].line1) + '' + '' + '' + google_ads[i].visible_url + ' ' + makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
' + ''; // '' + // makeBoldAdWords(google_ads[i].line2) + ' ' + // makeBoldAdWords(google_ads[i].line3) + // '
' + // google_ads[i].visible_url + ' ' + // '
' + // ''; } } } document.write(s); G_GGL_SKIP += Math.min(google_ads.length,G_MAX_ADS_AT); return; } var G_MAX_ADS_AT = 4; //var G_MAX_ADS_AT = 3; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "4447185069+3033438690"; google_ad_output = 'js'; google_max_num_ads = '4'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // -->
Sep 24, 2011 | Maytag Dryers
I have a whirlpool dryer that won't start. I am renting and the owner doesn't know the model number. The power to the house went out and everything came back on except the dryer. I checked the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 06, 2011 | Whirlpool LGV4634JQ Gas Dryer
My Kenmore dryer won't stay on when you push the start button it starts and turns off real quick. I have gotten new fuses and replaced them and it still won't work.
heatman101
Jun 01, 2011 | Dryers
Dryers Logo
20 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
