Question about Toshiba Canvio Computers & Internet
Error code: 0x81000019 backup
Shadow copy could not be created
Jastababe
  • 117 Answers
SOURCE: System State Backup problem
That specific error pertains to "validating" your copy of Windows. you might want to validate that copy, then re-try system state.
~~Jasta~~
Posted on Mar 24, 2008
SOURCE: System State not successfully
shotdown your computer
Posted on May 14, 2008
  • 7 Answers
SOURCE: Volume shadow copy backup error : 800423F1
http://support.microsoft.com/kb/833167
u may reffer this for sol.
Posted on Jun 17, 2008
Batstar
  • 122 Answers
SOURCE: backup failed--a shadow copy could
The drive you are trying to backup to has run out of space, you need to make sure your backup drive/partition has enough room available for the backup your trying to run.
Posted on Nov 09, 2010
rocky_eagles
  • 149 Answers
SOURCE: error code 0x81000019
Does your motherboard support USB 3.0?? I'm using Go-flex too but it is working fine so far on USB. 2.0. or could you give some of computer or laptop 'spec'?
Posted on Nov 18, 2011
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
Error code 0x81000019
Nov 16, 2011 | Microsoft Windows 7 Ultimate for PC
When i try to transffer data to the sandisk sd 2gb card im getting 0x8007045d error help please
it is because your card is formated as FAT ( this means that you can only store small files on it ). To fix this do the following 1. open my computer 2. right click on th sd card 3. press format 4. in format select fat32 instead of fat 5. click format (you will lose all data currently on the card) 6. when it is finished you should be able to copy files onto it
Mar 16, 2011 | SanDisk 2GB microSD Memory Card
Backup failed--a shadow copy could notbe created, insufficent storage available to.create a shadow copy storage file, or other shadow copy data.------ox800423if
Nov 09, 2010 | Computers & Internet
I am receiving the following message when I attempt to access my Western Digital My Book 500 GB: "Ox8007045D I/O Device error" I can see that my photos are still there but cannot open them or copy into the...
Happened to me too in both file backup and computer backup. I supposed MS will address in the future. For now, go to the system settings and unchecked the drives so they no longer create shadow copies . Apply the new settings to erase all existing shadow copies. Then reset by checking the boxes you unchecked. Now try to backup the whole computer again. It appears a shadow copy error is conflicting with the backup process. Once you delete all shadow copies (restore points) it will work.
Jan 05, 2009 | Western Digital My Book Essential Edition...
Jun 13, 2008 | Microsoft Windows Server Standard 2003 for...
~~Jasta~~
Mar 24, 2008 | Microsoft Windows Server Standard 2003 for...
This is common in the following OS.
• Microsoft Windows Server 2003, Web Edition • Microsoft Windows Server 2003, Standard Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise x64 Edition • Microsoft Windows Small Business Server 2003 Premium Edition
This problem occurs when the following conditions are true: • You back up data from a volume that contains a Microsoft SQL Server database. • The recovery model of the SQL Server database is configured to use an option that is different from Simple.
Submit a request here to get a hotfix from Microsoft ( Its free and no product key will be asked )
http://go.microsoft.com/?linkid=6294451
Feb 18, 2008 | Microsoft Windows Server Standard 2003 for...
Error copying file or folder
One of the most important yet overlooked elements of PC maintenance is data backup. If you do not perform regular backups, chances are your productivity will eventually suffer from data losses or a failed Windows installation.
All versions of Windows after 3.1 ship with a free backup utility called Microsoft Backup. It is not the best backup program available, but it may be sufficient for your needs. (Backup is better in later versions of Windows. Microsoft recommends Win98/Me users purchase a third-party utility.) If you want more control over your backups, consider purchasing a third-party program.
Backup is part of the System Tools utility. However, Setup does not install it by default in Win98/Me/XP Home. If you cannot locate Backup, visit the Microsoft support site and query for article No. 152561 (Win98), No. 264541 (WinMe), or No. 302894 (WinXP Home).
In Win98/Me, click Start, select Programs, Accessories, System Tools, and click Backup. To create and run a backup, click the Create A New Backup Job radio button and click OK. Follow the prompts to create a full or partial backup. If you want to create a backup set and run it later or run an existing backup set, open Backup and click the Open An Existing Backup Job radio button and click OK. You can now access the main Backup dialog box.
In Win2000/XP, navigate to the System Tools utility and select Backup. Click the Backup Wizard button. If you do not see a Backup Wizard button, click the Welcome tab. In WinXP, the wizard will start automatically if you are in wizard mode. Follow the prompts to create your backup set.
When you reach the last dialog box, Completing The Backup Wizard, you can click the Advanced button to create a backup schedule (this option is not available in Win98/Me). When you reach the When To Back Up dialog box, select the Later radio button and click the Set Schedule button. Perform data backups on a schedule that is appropriate to the importance of your files (once a week is a common timeframe). You should also perform a system backup at least once a month.
If you do not want to use the wizard, or you are working with an existing backup, open Backup and click the Backup tab to access the main Backup dialog box.
Feb 11, 2008 | Buffalo Technology 250GB USB SATA 2.0 HD...
Computers & Internet Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
