Question about Refrigerators
Maytag Wide by Side Freezes everything.
Maytag Model MZD2768GEW, Wide by Side Climate Zone drawers are freezing everything. This model has 3 drawers. The top 2 are Climate Zone drawers, and the bottom drawer is "automatic humidity controlled." Foods are freezing in all three drawers and I will find frozen produce on the bottom shelf above the three drawers. We have changed the temperature settings for the refrigerator and freezer resulting in no correction of the problem. The temperatures in the two "climate zone" drawers keeps flipping back to 25 degrees, and the temp will not drop even if the drawers are left open long enough for the temperature to drop at least two or three degrees. I can't tell if the automatic defroster is working or not, but there is no frost build-up anywhere inside the refrigerator side or the freezer side. (Except the the chute on the ice dispenser - more an annoyance than a problem because it is in constant use and the materials used) Any help will be appreciated!
4 Suggested Answers
  • 8 Answers
SOURCE: climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Posted on Jul 11, 2009
SOURCE: MSD2758GEW Climate Zone Drawers
This fridge is garbage. Fixed ours 14 times in 6 years. WILL NEVER BUY ANOTHER MAYTAG ANYTHING AGAIN!!!! CLIMATE ZONE TECHNOLOGY DRAWERS NEVER DID WORK CORRECTLY....EVER.
Posted on Feb 08, 2011
  • 183 Answers
SOURCE: GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Posted on Apr 09, 2012
When was this Modle made MZD2768GE wide by side with 3 self temp drawers?
MZD2768GEW W stands for White. We bought ours in early 2004, so I am assuming it was made in 2003.
Jun 19, 2011 | Refrigerators
My bottom drawer of my 3 year old Maytag fridge is freezing up all the items I put in it. The fridge is on its lowest setting. What's up?
You mentioned that the fridge is at its lowest settings, try up it a bit so it doesn't freeze up your items.
Feb 04, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Oct 06, 2009 | Refrigerators
Some fruits and vegs freeze in drawers, but not all
GE fidge it is a common problem...air dampers stuck wide open..too much cold air going to fresh food side from the freezer..you need to call repair man
!!! but if you still want to do repair by yourself, send me model number i send you some ideas and most important some images...so you can put everything back together after you done :)))
totalcarefl@yahoo.com
Aug 29, 2009 | GE Refrigerators
Climate control drawer is 20 degrees, freezes everything,
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Jun 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Jan 31, 2009 | Maytag MSD2758GEW
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
