Question about Acura 2004 MDX Touring with Navigation S
Acura mdx makes loud humming noise when first starting up
The noise gets louder when turning the steering wheel, after awhile the noise does go away.
SOURCE: Acura MDX 2008, 6k miles. Steering wheel vibrates
you will find that it is as cheap to just by replacement rotors from Autozone or Advance Auto...that is what I did and it solve the problem.
Posted on Oct 07, 2009
  • 1201 Answers
SOURCE: why is my acura mdx making a whining sound when I
If it is only making that noise when you turn the wheel, it's probably low on power steering fluid, adding some to full mark should cure the problem.
Posted on Oct 19, 2009
  • 3600 Answers
SOURCE: My 2004 Acura MDX is making a whinning noise. we
the fluid could be burnt and the filter may need to change. You would aslo need to check the air in your tires to see if one of the front tires is low on air, then the next thing would be to check to see if a brake caliper is sticking.
Posted on Apr 16, 2010
  • 743 Answers
SOURCE: I want to replace my
If it is cranking but just takes longer to start then that is not caused by the starter. May need a tune up and/or a fuel filter. May also want to check fuel pressure and listen for the fuel pump to turn on for about 2 seconds when the key is first turned on.
Posted on Aug 24, 2011
SOURCE: 92 acura legend steering wheel won't return after making the turn
Possibly valve body in steering mechanism, try changing oil in steering .
Giltronics
Posted on Oct 23, 2012
Power steering noise
It could be a loose engine belt, you could be low on power steering fluid or your pump could be going bad. If 1 and 2 check out then you probably need a new pump.
Apr 08, 2014 | 2003 Acura MDX
Acura 2007 mdx transfer/bearings or tires noise?????
May be a wheel bearing ,if it is driving straight and weaving
left and right will change the noise.(louder turning one way
than the other)
Jan 30, 2013 | 2007 Acura MDX Tech
2004 town and country whining noise louder when turning the steering wheel
Bad steering rack & or steering pump
Try flushing the fluid, as you should be doing every 3
years on all vehicles
After that-- have to diagnose & start changing parts-- if
you don't like the noise
Nov 23, 2012 | Cars & Trucks
I have a 2000 Honda Accord and as I accelerate over 45 mph the care starts making a progressively louder humming/buzzing sound. When I turn slightly to the right the noise will go away. Any ideas wh
sounds like the wheels are out of balance, is there a slight vibration through the steering wheel at this speed? and does the problem stop if you go faster (please drive carefully)
Jan 24, 2012 | 2000 Honda Accord
My pontiac montana 1999 is making a loud humming sound only when iam moving. The faster I go the louder it gets and every once in awhile it jerks
you will have to ask a local mechanic to diagnose this noise for you as without hearing the noise i have no idea what it could be ,if i could hear the noise i could tell you straight away ,sorry to be a bore but its one of the joys of motoring as this noise could be a wheel bearing or a water pump and without hearing it ???'
May 17, 2011 | 1999 Pontiac Montana
Front wheel bearings bad
if it gets louder when you turn left then the right front wheel bearing is bad and vice versa it gets louder when the weight shifts to that wheel
May 05, 2010 | 1996 Pontiac Sunfire
Why is my acura mdx making a whining sound when I turn wheel
Oct 19, 2009 | 2004 Acura MDX
Hi, I have a chrysler pt cruiser 1991, it is making a loud throaty noise as I go up in gears, it's not the exhaust.
HI" does this noise go away when you step on the clutch pedal and does this noise gets louder as you go faster, try turning the steering wheel a little see if noise goes away that would indicate bad wheel bearing
Sep 23, 2009 | 2001 Chrysler PT Cruiser
Loud whirring noise at start-up
The first thing to check would be to make sure the power steering reservoir is not running near empty, locate the filler cap for the power steering pump it should be marked and then add the appropriate amount making sure you don't over fill, that may make the sound go away if not we must move on to the next possibility, by the way if the noise gets louder when you turn the steering wheel it is most likely the power steering pump or fluid level is low.
Jul 14, 2009 | 1998 Mitsubishi Galant
Car makes funny noise upon starting on very cold days
Have your power steering belt checked and adjusted, or replaced if worn.
Jan 20, 2009 | 1998 Plymouth Breeze
Open Questions:
Rearview backup camera not working, flashing screen. Not tailgate camera wire problem. Please Click "Want Answer" to get this question answered. Just to start out, I have replaced the entire camera wiring harness so a broken wire there should not be the culprit.I've had the MDX for a 4 years and the camera and Navigation have not worked for years. I recently replaced the Navigation unit hoping it would also fix the camera issue. Now the Nav is working as it should but the camera is still not working, still flashing between black and white with no picture visible. I have been able to bring up the brightness menu through the nav screen to adjust up or down screen brightness but it has no impact when I increase or decrease the brightness. I've read a lot on about every possible forumn. When my MDX is in reverse, my backup camera does not work. I did research and find the most common reason for failure related to severed wires (red wire usually) in the passenger side boot between the tailgate was broken. Mine was broken too and I started with soldering the wires together but that didn't work. I then purchased ($28) a new OEM Rearview Camera wiring harnes from Acura. I replaced the entire wire harness to solve the issue but the camera still does not work. All fuses are checked and good, reverse lights work, light bulb in hatch door is working. No damage in wires between the Camera and new wire harness. That leaves me with a possible bad Rearview control unit (havent been able to find this yet) or a bad camera assembly. Maybe some other internal wiring issues between display and control unit. I've tried to take the passenger side interior panels off but saw it was going to be a pretty big job so I thought I should ask before I gave up. Please help. I have a cheaper volt meter, has red and black lead, but haven't learned how to use or read it yet. I wish I knew. The main difference I have noticed between others that have been able to fix their problem by reconnecting the wires is that their screens are blank, which indicates they just aren't getting power to the camera. My screen flashes between white and black about every second.
May 25, 2016 | Acura 2004 MDX Touring with Navigation S
Acura 2004 MDX Touring with Navigation S Logo
24 people viewed this question
Top Acura Car Audio & Video Experts
xxxxxx xxx
Lawrence Oravetz
Are you an Acura Car Audio and Video Expert? Answer questions, earn points and help others
