Question about Vehicle Parts & Accessories
Bmw convertible roof and trunk lid do not open
Periodically the convertible roof and the lid of the trunk on a BMW 320 do not open, although the roof can be opened manually. What is the solution to this problem?
BeamerGuy
  • 28 Answers
SOURCE: 1997 BMW 328i convertible
The problem is that your roof(SOFT TOP) lid isnt closing properly. If you open the roof lid you see there is a button on one of the latches that tells the car that the roof is securely closed if your roof lid is not secure the trunk wont open. To test this press down on the roof lid and the try to open the trunk.
Posted on Jun 15, 2008
BeamerGuy
  • 28 Answers
SOURCE: Convertable roof and trunk won't open
The Roof Mechanism works with two motors similiar to the ones that wund the windows. Now the two mechanism are located in the left side of the trunk.
The trunk wont open Because of the roof lid that is not closed properly. How you can test this is to press down on the right sid of the roof lid and then try to opne the trunk.
Now the reason that this is happening is that the roof lid is not closing properly nad pressing on a small orange buttin located just below the right hand side roof lid catch. How you are going to remedy this problem is to adjust the cable tension to close more securely.
Now the two motors in the trunk that works the convertable roof can be engaged and disengaged on motor works the roof lid and the other one the roof.
You need to get these motors in sync so that they open and close the roof in the correct order.
That is if the electric are still working.
Posted on Aug 05, 2008
BeamerGuy
  • 28 Answers
SOURCE: convertible top will not retrack
Hi Stan
First of all the roof is not even soppose to operate while the trunk is open - So there is the first problem Ive been involved with BMW's for a long time and this is the first Ive heard of a roof opening while the trunk is open. There is a built in feature that tells the car not to open the roof if the trunk is open and the other way roung while the roog lid is open the trunk cant open.
The reason the roof is not working anymore as soon as there is stress on the roof the electric motors(One operates the roof and the other operates the roof lid)  disengages, You said that the roof still worked but the lid did not so probably only the one motor disengaged. So what you have to do is open the trunk on the left hand side right behind the tail light pull away the material and simply just push the electric motor into place. that should fix your problem.
It may happen that the two motors have become out of sync, Disengage both electric motors manualy put the roof away engage the motors and that should put the roof and lid back into sync.
Beamerguy.
Posted on Nov 21, 2008
  • 126 Answers
SOURCE: BMW X 3 Panoramic sun roof initialization.
title says X5, but description says X3. i'll explain for an X5, but X3 with the pano should be the same. and i'll explain function of the roof, not reprogramming.
button is located on the panel at the top near the front & center windshield. its the switch on the far left on this panel. its a switch that not only toggles, but also slides forward & back.
with your finger in front of the button, slide it back & release. this will make the cover slide back and store revealing the sun roof. you know have 2 options (tilt the sunroof up or open the roof completely).
to tilt it up, press up on the rear of the button and release. the rear of both roofs will pop up. to close, push up and release the front of the button or slide the switch forward.
to slide it open completely, repeat what you did to open the protective cover (slide the switch from front to back). the roof will open completely and stow out of the way. to close, slide the switch forward and release. pano roof will now close.
to close the cover, slide the switch forward again.
neat trick: if you want to tilt the sunroof open without opening the protective cover, press up on the rear of the button (when the cover is closed) and release. the cover will separate in the middle exposing about a 2-3 inch mesh, then tilts the sunroof open. to close, push the button forward again.
also, if you are above a certain speed (can't remember what it is off hand) with the sunroof open or tilted, it will close automatically, then perform the neat trick on its own to keep air coming in.
one last trick: if you want to open the windows and sunroof from outside, press & hold the unlock button (forward button on the key) and you will see the windows go down, then the roof will open to vent. releasing the button will stop the motion of the windows & roof.
hope this answered what you were asking.
Posted on Jan 28, 2009
SOURCE: 2006 BMW 750Li Trunk will not open
check inside the center console i think there is a lock and unlock button for the trunk make sure it is unlocked then try it with the remote.
Posted on Jun 14, 2009
1997 BMW 3281 CONV.TRUNK WILL NOT OPEN LOCKS AND UNLOCKS ,BUT WILL NOT UNLATCH HOW CAN I OPEN IT
Search the BMW forums like Pelican Parts or DTM Power or United Bimmer Community. When I read of problems with convertible trunk lids, a common suspect is a failure in the system that won't allow the trunk to open when the roof is down.
Feb 24, 2011 | 1997 BMW 328
Tip
Your Convertable's trunk not opening?
If the trunk of your convertable is not openig nit is probably because the convertable roof lid is not closing properly, To check this simply press on the roof lid while someone then try's to open the trunk.
on Nov 21, 2008 | 1997 BMW 328
1997 BMW 328ic convertible top stop working. We had to manually close the top but the roof light is flashing. now I can not open the trunk. We tried taking the back seat out (instructions in the owner's...
the trunk will not open because the rear deck lid is not latched.if you have someone push down on the rear lid the micro switch contact will close and then the trunk should be able to be opened
Jan 31, 2011 | 1999 BMW 328 Series
1999 bmw 328i convertible trunk will not open with button or key what do I do
UPDATE: I thought I was posting regarding a 1998 E36. Not sure a 99 has the same fuse or interlock.
Jun 24, 2009 | 1999 BMW 328 Series
1997 Convertible BMW 318i top roof storage wont open
Hi, I don`t know the car but sometimes when you can`t open a boot lid someone need to push the boot lid down ( this relase the pressure of the latch system)and the same time someone pull the handle. Hope that helps.
May 28, 2009 | 1997 BMW 318
Convertible top will not retrack
Hi Stan
Beamerguy.
Nov 08, 2008 | 1997 BMW 328
Trunk and hood manual latch won't work
That is not the problem the problem is your convertable roof is not closing properly to test this let someone press down on the roof lid and then try to open the trunk, To fix this let the roof lid open and let the roof come up until the back part stands up to let the roof lid close so that the roof hold is exposed look on the right hand side of the car (if your standing at the back) under the roof lid catch there is a small plastic buttun that the roof lid catch needs to pres down on, this tells the car that the roof lid is seucre and it is now safe to let open the trunk, All you have to do is set the tension on the cable for that roof lid catch and the problem is sorted.
Beamerguy
Sep 03, 2008 | 1997 BMW 328
Jul 24, 2008 | 1997 BMW 328
Jun 15, 2008 | 1997 BMW 328
BMW Convertible Electric Roof Rack
the trunk is your back lid.
there should be a switch where you insert your key to open it
turn it until it locks
and check the light to see if is still flashing
May 21, 2008 | 1997 BMW 318
Vehicle Parts & Accessories Logo
13 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
