Question about Hamilton Beach 1.1 Cu. Ft. 1000-Watts Compact Digital Microwave Oven White
How to change the light bulb in microwave
Light is burnt out
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
Ge spacemaker xl jvm1340
If you had too high a wattage the excess heat may have melted the wires or ruined the switch.
Nov 28, 2013 | Microwave Ovens
I have a GE JES 1855 Microwave Oven, my light bulb burnt out there is no instructions telling you how to replace the bulb!
You have to take the out side cover off and there you will see how to change the bulb.
Jul 03, 2011 | Microwave Ovens
Exterior light is not working. The fan turns on, but the lights won't when the button is pressed.
Is the light bulb burnt out? Try replacing the light bulb and see what happens.
Nov 14, 2010 | Whirlpool MH6141XK Microwave Oven
Light has burnt out
R-820BK/BW Microwave Operation Manual
Due to the risks of death or serious injury the above owners manual suggests that a burnt out light demands a service call by a qualified technician.
That said, if you have a basic level of competence and read the safety hazards involved with microwaves (see a good resource on microwave safety and repair at:
http://www.kellerstudio.de/repairfaq/sam/micfaq.htm
Often, the microwave is divided into two main compartments, the electronics compartment(usually immediately behind the front control panel), and the high voltage compartment(usually behind the electronics compartment). The light bulb is likely in one of these two primary compartments. If it is in the high voltage compartment with the HV Capacitor and magnetron, changing the bulb becomes much more dangerous.
Please be very careful if you do decide to do this on your own... unlike most electronics microwaves can remain lethal, even when unplugged. Hope this helps.
Oct 21, 2010 | Sharp R820BK 900 Watts Convection ...
Lights and vent do not work
I have ran into a few of these that shorted out the control board when the light bulb burnt out. Depending on how far you want to go, you can take out the board and look for a burnt spot and possibly repair the board. Or purchase a new board, which may be more than what you want to put into the microwave.
Jun 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave light is burnt out
Accessing the internal light bulb on model KBMC140HSS bulb will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 14, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hamilton Beach 1.1 Cu. Ft. 1000-Watts Compact Digital Microwave Oven White Logo
35 people viewed this question
Top Hamilton Beach Microwave Ovens Experts
Are you a Hamilton Beach Microwave Oven Expert? Answer questions, earn points and help others
