Question about Mackie SRM-450 System
How to change the hf unit? - Mackie SRM-450 System
    Problem Solver:
  • 18 Answers
A new diaphragm can be fitted into the original driver and the speaker will be like brand new. first you must determine if you have the older RCF version (M44TI) or the newer Mackie versions (0008093). There is only one RCF diaphragm that will work for this repair and they are scarce. There are both authentic and aftermarket Mackie diaphragm options and both work very well.
cathy@speakerex.com
Posted on Jun 25, 2009
No HF & weak LF response in a Yahama DXR-15 powered speaker
This unit has a class D switching amplifier which is complex enough to be unfixable by you unless you know what you're doing. It would seem from your diagnostic report (dodgy HF LF response) that you're not in any way a qualified bench tech and all you can do with this item is break it further. My advice - since it's still covered under warranty being that it's rather new, return it for a no cost repair at the store where you bought it.
Nov 19, 2013 | Yamaha DXR15 15" Active Speaker
Tip
Convert/Import, Edit Canon VIXIA HF Series Video to Mac, iMovie, Quicktime
Canon VIXIA Camcorder has a good reputation for its small size, recording video in full HD quality, lightweight, etc. Just like popular Canon FS series camcorder, Canon VIXIA HF series Camcorder is a large family including VIXIA HF R-series like VIXIA HF R10, VIXIA HF R11, VIXIA HF R100; VIXIA HF M-series such as VIXIA HF M30, VIXIA HF M31, VIXIA HF M300; VIXIA HF S-series like VIXIA HF S10, VIXIA HF S20, VIXIA HF S21, VIXIA HF S200, and some other popular VIXIA types such as VIXIA HF10, VIXIA HF100, VIXIA HF20, VIXIA HF200, VIXIA HG21, VIXIA HG20, etc.
Most of Canon VIXIA HF series camcorders record videos in AVCHD MTS files. If you want to share these AVCHD MTS files with family or friend on Mac, you may cannot directly playback these MTS videos with your Mac, iPad, iPod, iPhone, or Blackberry. If you would like to customize Canon VIXIA HF video on Mac, you may cannot directly edit MTS videos in iMovie, FCP, FCE, etc. What should we do about this? The best solution is to transfer Canon VIXIA HF video to Mac supported video format such as MOV, MP4 that are aslo for iPad, iPod, iPhones, Blackberry, PSP, etc.
AVCHD Converter for Mac is the best choice for you to convert Canon VIXIA HF video to MOV, MP4, AVI, 3GP, MPEG-4 for Mac so that you can import these AVCHD MTS/M2TS files to iMovie, iTunes, iDVD, FCP, FCE etc for editing. Besides, this Canon VIXIA Video Converter for Mac also has powerful editing function like trim video length, crop video, set video brightness, contrast, and saturation, and customize video/audio output settings, etc.
Now, easy tutorial for you to convert Canon VIXIA video to Mac OS step by step.
Step One: Import Canon VIXIA HF Video to Mac AVCHD Converter
Firstly, you need to copy your Canon VIXIA video to Mac and launch AVCHD Converter for Mac, then you can click "Add File" to upload your AVCHD MTS files on Mac.
Step Two: Set Output Video Format for Mac
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS.
Step Three: Convert Canon VIXIA Video to Mac
Click "Start" button to convert Canon AVCHD MTS files for Mac. After conversion finished, you can edit your converted MTS, M2TS files with iMovie, FCP, FCE, iDVD, etc as you like.
on Oct 13, 2010 | Computers & Internet
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
JBL EON15-G2--Does the HF Amplifer to the driver have any voltage?
The 2 leads that come off the HF driver are different sizes...you should only be able to hook them up one way. Takes the guess work out of it for ya.
Assuming there is nothing wrong with the speaker, hooking up the 2418H HF driver to it should do the trick. However, I blew my HF driver a few months ago and bought a new one, only to blow it immediately. This was because the motherboard of the JBL EON G2 had actually failed and caused the HF driver to fail. Once I replaced the motherboard and the HF driver (again) everything was back to sounding great. Hope that helps.
Oct 10, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Blown Compression Drivers
This unit features 2 -10" passive speakers and HF horn/driver. If you are blowing the HF driver, the problem is with overdriving the high range of EQ. At sustained high volumes, the voice coil of HF driver will overheat and open. If you still have effective warranty, ask Yamaha to replace drivers. Fixed,-- back off higher frequencies of EQ, turn down volume.
Apr 16, 2008 | Audio Players & Recorders
Bi amp
Hi there, I am assuming that you wish to BiWire the speakers. This involves removing the link on the back of the speaker box and running additional speaker leads for the HF drivers, as well as cable for the LF drivers. BiWiring allows you to use different cable that has been designed with high frequency signal path in mind. It may feature things like silver plating, low capacitance, or as many other "features" as can be tagged to the cable to sell it as a specialist HF conductor. The benefits may be subtle, and not be that noticeable. It does isolate the potential voltage drop along the length of the cable associated with LF energy away from the HF side of the speaker system, and take advantage of Skin Effect, where HF energy tends to travel on the surface of the conductor.
Using a single cable for each channel and leaving the links fitted is perfectly fine and will operate no worries. You could go and spend the extra cash and upgrade your cables to HF and LF BiWire.... the sky is the limit on cost here for what may not be a noticeable difference:)
BiAmping in a different story where much more performance increase is achieved by using a separate channel to amplify HF and LF signals. But you need an amp that has a built HF and LF outputs for each channel to do this. They exists but I have not seen any surround amps that have it.
Go with decent quality realistically priced speaker cable first, then add your HF BiWire to the rig if you are looking for that little bit extra from it:) Good luck, and happy listening.
regards
Graeme
Feb 28, 2008 | Monitor Audio Bronze B4 Speaker
Will not power up
your problem is in flyback or high voltage section failure.
  • check horizontal output transistor
  • check fly back transformer.
  • check for supply to horizontal section as high voltage from power supply may create such problem
  • as this failure is due high voltage section so it is better to take skilled technician help.
  • good luck.
Oct 15, 2007 | Toshiba 27A51 27" TV
Mackie SRM-450 System Logo
298 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
