Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
What is the max Kw usage of the Amana AC2224GEKB? Thanks in advance.
  • 72 Answers
744 KW annually, approximate running cost of $157
Posted on Jun 15, 2009
Low engine power
i have same problem. 50KW max, gas consumption 18 litres plus...
Mar 09, 2014 | 2007 Hyundai Getz 1.4
Need to know if I can run my fridge on small generator if there is power outage. Generator is 1600/1650 Watts; Amana fridge model TC18HG nameplate says 6.5 Amps. But I'm unsure about the starting...
Hello Bob,
There should be absoluty no problem on that 1600 watt generator..at max when compressor just starts its drawing about 750 watts, that is the max usage when running its about 500 and on defrost its like 850 ..so on 1600 watt generator no problem
Aug 25, 2011 | Amana Refrigerators
I would like to run my frigerator if possible , off an inverter if our power goes out from a hurricane. I need to know the surge draw in watts for the start up and the running draw in watts after...
During the 2 peak power usage times of the refrig,on start up and during the defrost the max wattage would be 1320 assuming the compressor might potentially be tight using more power to start than if it were/is normal for a max of as said 1300 with the normal statrt up be around 800. and when running after starting it would be a max. of 500
Aug 05, 2011 | Amana Refrigerators
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
The SYSTEM process hiked to 100% usage after installing the VGA drivers. Please Assist me. Thanks in advance.
check which process is utilizing maximum usage. for that to locate go to task manager, in that see process tab and locate the process which is utilizing the max usage. Right click the process which utilize maximum processor usage and end it.
Sep 04, 2009 | Intel D101GGC Motherboard
I have a 247 03 Springdale RV trailer. I want a
Depends on wattage demand of ac unit. VXA=W 110x20amps=2,0200 Watts. A 2,00 watt generator is too small. Best go for a 3,kw genset. A 5 kw will leave you room to run appliances and the ac simultaneously., otherwise you will need to watch your margin usage. I think 4.5 kw gensets are also available. Happy trails.
Jul 25, 2009 | Heating & Cooling
1854-Yamaha V-Twin Motorcycle Engine
The horsepower of that mighty beast is exactly 100 horsepower (73.6 kW). Here's some of the other specs:
  • Engine Type - Air cooled, 4-stroke, V-twin engine, OHV, 4 valves
  • Displacement - 1,854 cc
  • Bore & stroke - 100 x 118 mm
  • Compression Ratio - 9.5:1
  • Max. power - 73.60 kW (100 HP) @ 4,250 rpm
  • Max. torque - 167.80 Nm (17.1 kg-m) @ 2,500 rpm
  • Jan 17, 2009 | 2006 Yamaha Roadliner
    Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
    111 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Sal De
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
