Question about Archos Mx6minicd External Minicd Drive Cds-1-t24
How do I install and use the miniCD?
How do I use the miniCD?
Product: Innovage Digital Photo Keychain Issue: Not holding a charge In a nutshell, the hardware works (I've already used the minicd to load the software, and have even put pictures onto the...
What probably happened is the battery slowly drained on the shelf and its shot. Basically the type of battery in these (and a lot of other devices) can not be left with a very low charge for long periods of time or it degrades them. What happened is the battery just degraded and now cant hold a charge.
Jul 05, 2011 | Computers & Internet
How do u set timing on it? 1.8 engine
Installation
Install crankshaft sprocket on crankshaft.
Make sure mating marks on crankshaft sprocket face front of engine.
Position crankshaft so that No. 1 piston is at TDC and crankshaft key is at 12 o'clock.
Install slack side timing chain guide and timing chain tension guide.
Install timing chain on crankshaft sprocket.
Set timing chain by aligning its mating mark with that on the crankshaft sprocket.
Make sure sprocket's mating mark faces engine front.
Install camshaft sprockets.
Set timing chain by aligning mating marks with those of camshaft sprockets.
Install camshaft sprocket bolts to correct torque.
Apply new engine oil to bolt threads and seat surface.
Install chain tensioner.
Before installing chain tensioner, insert a suitable pin into pin hole of chain tensioner.
After installing chain tensioner, remove the pin.
Install timing chain guide.
Install O-rings to cylinder block.
Before installing front cover, remove all traces of RTV silicone sealant from mating surface using a scraper.
Also remove traces of RTV silicone sealant from mating surface of cylinder block.
Apply a continuous bead of Genuine RTV Silicone Sealant or equivalent to mating surface of front cover. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Check alignment of mating marks on chain and crankshaft sprocket.
Align oil drive spacer with oil pump.
Place timing chain to the side of chain guide. This prevents the chain from making contact with water seal area of front cover.
Install front cover.
Make sure two O-rings are present.
Be careful not to damage oil seal when installing front cover.
Install cylinder head bolts at engine front side as shown in Fig. 55.
Tightening procedure:
Tighten bolts (1 - 4): 6.3-8.3 N.m (0.64-0.85 kg.m, 55.8-73.5 in.lb).
Install oil pump drive spacer.
Install water pump and water pump pulley. Refer to REMOVAL AND INSTALLATION .
Install idler pulley and bracket.
Install RH engine mounting bracket
Install RH engine mounting.
Install oil pan. Refer to INSTALLATION.
Install crankshaft pulley.
Remove ring gear stopper.
Install starter motor.
Install cylinder head front cover.
Apply RTV silicone sealant to cylinder head front cover.
Use Genuine RTV Silicone Sealant or equivalent. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Install Camshaft Position Sensor (PHASE).
Before installing rocker cover, apply a bead of Genuine RTV Silicone Sealant or equivalent, to mating surface of cylinder head as shown in .
Install rocker cover gasket into rocker cover.
Install rocker cover and tighten in numerical order as shown in
Install spark plugs.
Install ignition coils.
Install front exhaust tube.
Install front/right-side splash undercover.
Install front RH wheel.
Install drive belts.
Adjusting drive belt deflection..
Nov 29, 2010 | 2002 Nissan Sentra
I have the Sony WalkmanMZ-R700 and the digital pclink device an cables. How do I transfer songs from the walkman minicd to my computer?
As you would for any other analog stereo device. The only outputs are analog headphone x 2 (requires stereo mini plug). Your sound card and PC software would be the limitations.
http://www.retrevo.com/support/Sony-MZ-R70-manual/id/267ag214/t/2/
Sep 15, 2010 | Sony Walkman MZ-R700 Personal MiniDisc...
My computer recognises the hard drive as a folder, and can't access the hard drive to search the contents. any ideas how to fix this?
Check if you hard drive is recognised as dynamic disk (device managment-disk managment), those can be mounted into folders!
TRY to access the drive from DOS PROMPT, to lunch one, go "RUN", and type CMD.
TRY to access your drive frome the adress bar on top of MY COMPUTER window, enter the letter of your drive and hitt enter. (the drive my have missing/extra files manipulating its access, the file can look like "autorun").
If none of the above was helpfull, dont give up, WIN PE minicd can always help, google for it , download it, burn it, and run it, you will certainly find it helfull, and you can access your disk in the browser, and copy the files into the working location!
GD luck
Jan 01, 2010 | VMware Workstation 4.x (WS4-ENG-W-CE) for...
0x10090 error in st94011a hard disk
bad cluster.....or partition table!!!!
boott up winpe minicd....and make some changes...dnt forget format!!!! gd luck
Jul 13, 2009 | Seagate Momentus 40 GB Hard Drive
Install A4 tech PK635 M web cam without cd installer
help me solve my problem give me installer
May 19, 2008 | A4tech PK5
Viewty sync to mac
LG has not yet developed the drivers for mac. And you won't find them on the CD, so don't get crazy to put the minicd con the mac... it won't be useful. Just monitor the lgmobile.com mobile for the drivers to be published. LG has promised them for the first half of 2008. Until then, you can only use USB or Bluetooth to exchange data.
Apr 11, 2008 | LG KU990 Viewty
Installing the Photo Viewer Software
Have you tried to up load without additional software.
I am not MAC fluent - but Windoze can take up camera images with out extra software.
Perhapa Mac's can too
Dec 13, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
210 meg mini cd
have you tried the cd's on different computers or on a different cd drives? Ive had many issues with cd drives before, many times the reading laser and mechanisms fail and all sorts of strange things happen. In my experience not being able to read cd's on a CD drive or DVD drive is almost never a software issue, but acutally almost 99% of the time it is hardware related. I recommend to try those cd's on different machines. If they work on other machines its time to replace the CD drive.
Dec 09, 2007 | Computers & Internet
Archos Mx6minicd External Minicd Drive Cds-1-t24 Logo
Top Archos Computers & Internet Experts
fordexpert
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
