Question about Peavey Music
Pv10 will not come on. lights flicker for an instant and that is all it does.
Pv10 will not stay on
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
Got the right power supply/wall wart?????
Posted on Sep 20, 2014
Unit powers on, is unresponsive
It sounds like you need to take it in for repair.
May 07, 2015 | Behringer US600 Ultra Shifter/Harmonist...
No power
switched mode power supply and class d amps, take to shop that can work on these, it should of had a 5 year warranty.
Mar 30, 2014 | Peavey XR 1212 Powered Mixer Mixer Powered
When I turn on the amp, the lights flicker for a second but it does nothing else. The fuse is good.
Did you check that F1 (red arrows)?. You must open the aluminum cooling in order to find the fuse F1, because it was on the inside, not visible. Usually one of the causes of rupture F1 is one or more diodes (d4/d5/d6/d7) is broken. Check and measure the diode. May also occur, F1 break up just like that, without any other components that causes. This can happen when we open a high level for a long time. It is designed so that the final transistor (which is expensive) not be damaged. Hope it helps. ecae9d89-5530-4ca0-9f14-2f9321ab0aaa.jpg
Mar 16, 2014 | Behringer Bx4500h Ultrabass 450w Bass...
When i plugged it in the lights started flickering and some smoke came out. Now when i plug it in it won't turn on
sounds like you blew some resistors, or perhaps melted something. Take it in to a specialist and get a quote for repairs
Jan 29, 2014 | Behringer Vt100fxh Virtube 100-watt Guitar...
I want to know how to connect a powered subwoofer to the peavey 10 mixer
Connection is hooking up from mixer's main outputs (L,R) to
Subwoofer amp inputs.
Oct 10, 2013 | Peavey Electronics Peavey PV10 Mixer
Yamaha dgx 500 keyboard
Unplug and leave it unplugged for a while and then make sure the plug is nice and secure on both ends and try again
Jul 28, 2013 | Music
Belly and the bridge wont stay glued
Probably using wrong glue. For instance, using super glue is ridiculous as it is brittle and will break instantly. You should probably take this to a Luthier to have it setup. It should not cost that much for the repair and properly setup.
Apr 18, 2011 | Lag T200 DCE Acoustic Electric Guitar
All lights flickering
This is likely a power supply problem...
Be very careful to use an isolation transfprmer when working on the supply in this as there are lethal voltages.
May 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Turn it off and leave it off till it is fixed.
There is a problem in the PMP5000 that is LIKELY in the PMP3000 as well.
The problem is arcing in the rear-most power amp near the heatsink.
When this gets bad, it will short out and fry the power supply and the amp if it persists. The arcing will trip the overcurrent sense and shut down the unit including the display until it finally goes completely.
I have repaired two of the 5000's now with identical problem. There is inadequate insulation in a multi-layer board in the rear-most power amp. The arcing occurs between the output lead of the switchers and the source lead circuit trace for the 9640 switcher transistors. The output switcher lead unfortunately is an internal circuit trace and hard to fix. Once burned, the board becomes carbonized and conductive.
NEVER run the unit without a speaker load on the unit.
Mar 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
