Question about Directv Televison & Video
Waterproof direct tv remote?
Other than using a zip lock baggy to waterproof a direct tv remote are there any other options.
How to unlock tcl tv. My tv turned to child lock. I dont have the remote help plss
Go to Google, and type in, 'how to disable child lock for TV model #' (type in the model of your TV); or you may be able to utilize the buttons directly on the TV that would allow you to access the menu that would display the option to disable the child lock function.
Nov 10, 2014 | Televison & Video
Child locked on my tv
Possibly, you will need an original remote to disable or turn off this feature. And some child lock can be accessible through neither MENU of your tv or remote. Check CHILD LOCK option to remove it. If it is a screen lock type of CHILD LOCK feature of tv (a Blue Background display a LOCK icon) and your original remote is lost, try a universal remote for you to possibly unlock it. Thanks for using Fixya.
Apr 21, 2014 | Televison & Video
I think my phone got wet and now when I turn it on the screen won't light up
Turn phone off!!!! Take back off and battery out if applicable. Put phone and battery in a sealed zip lock baggie, and fill it up with uncooked rice. Bag only needs to be big enough to fit your phone into comfortably. Leave in bag, do not open for at least 24 hours, then turn it back on and check your screen.
Sep 07, 2013 | Cell Phones
How to dry Pantech C610
I saw this on TV for drying out cell phones...just recently. First remove the battery. Then partially fill two zip baggies with rice. Put the battery in one bag and zip, then put the cell phone in the other and zip. Let stand overnight. They should be dry by morning. Let me know if this works. It really sounded too simple. But logic tells me that the rice WILL draw all the moisture out.
Jan 16, 2012 | Pantech C610 Cell Phone
How to dry a wet phone
it sounds funny, but, put it in a zip lock baggie with white rice for a day or two. be sure to zip it shut.
Nov 20, 2011 | Cell Phones
Have a vizio tv and an input locked messages appeared and turned the tv off . Now when you turn the tv on the tv shuts off. How can we fix this? We unplugged the tv and pressed the side . We plugged the...
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the side of the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV
6- Power the TV back on
Apr 27, 2011 | Vizio M370VT 37 in. LCD TV
Cant turn on set and remote wont work, how can I reset tv and remote to work after our grandchildren locked the fromt buttons ans remote?
hello it sound like the key lock has been activated
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
Dec 12, 2010 | Zenith R56W36 56" Rear Projection...
Was using this remote to work a zenith tv. Need
You can download the required manual with the detailed procedures from RCA support site here:
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesInfo.do?findManual=rcr311b
This is the direct link to the set up manual:
http://audiovox2.info/docs/rca_acc/man/RCR311B_DOC_OM.PDF
Direct link to codes list:
http://audiovox2.info/docs/rca_acc/man/RCR311B_DOC_OTHER.PDF
Hope this solves your problem. Thanks.
Sep 14, 2009 | RCA RCR311B Remote Control
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
Remote sensor in the TV
First Inspect the remote batteries. also make sure TV is not on a LOCK ON option... now, the sensor is a small smoothly part near the TV front buttons, you can clean it carefully FYI, exposing unit remote sensor to direct fluorescent or outdoor light may cause signal interference.
Nov 14, 2005 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
94 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
