Question about Cisco Systems - Unified IP Phone Expansion Module 7916 (CP-7916=) Expansion Module
How to use expansion module
Our IT Dept. assigned extensions; however, the expansion module is not on
Change the display name?
Administering a 1400 Series Digital Deskphone
Perform the following steps for each 1400 Series Digital Deskphone:
1. Log into the Avaya Aura Communication Manager administration interface.
2. Perform one of the following steps:
? If you are adding a new extension and want to assign a specific extension number, use
the add station nnnn command, where nnnn is the new extension you want to assign.
? If you are adding a new extension and want to assign the next available extension
number, use the add station next command.
? If you are installing the 1400 Series Digital Deskphone at an existing extension, use the
change station nnnn command, where nnnn is the existing extension you want to
modify.
The Station screen appears.
3. Perform one of the following steps:
? If you are administering a 1408 telephone, type 2410 in the Type field.
? If you are administering a 1416 telephone, type 2420 in the Type field.
4. In the Port field, type the port address.
5. In the Name field, type the name to associate with this telephone. Administering 1400 Series Digital Deskphones
20 Avaya 1400 Series Digital Deskphones Installation and Maintenance Guide
6. Configure the remaining fields on the Station screen pages. Keep in mind the following
information:
? If you are administering a 1408 telephone, the first eight call appearance/feature buttons
displayed on the Station screen are administered on the 1408 telephone. (Since the 1408
telephone is aliased as a 2410 telephone, the Station screen displays 10 call
appearance/feature buttons.) The remaining buttons displayed on the Station screen are
not administered.
? If you are administering a 1416 telephone, the first 16 call appearance/feature buttons
displayed on the Station screen are administered on the 1416 telephone. (Since the 1416
telephone is aliased as a 2420 telephone, the Station screen displays 20 call
not administered.
? If you are administering a 1416 telephone with a DBM32 Button module, the first 16 call
appearance/feature buttons displayed on the Station screen are administered on the
1416 telephone. The remaining eight call appearance/feature buttons displayed on the
Station screen are administered on the first eight buttons of the DBM32 Button module.
The 24 buttons of the EU24 expansion module displayed on the Station screen are
administered for the remaining 24 buttons of the DBM32 Button module.
For more information about administration and features, see:
- Administering Avaya Aura™ Communication Manager, Document Number 03-300509
- Avaya Aura™ Communication Manager Feature Description and Implementation,
Document Number 555-245-205
- Avaya Aura™ Communication Manager Screen Reference, Document Number
03-602878
7. When finished administering this extension, save your changes.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Dec 19, 2014 | Avaya Ip Office 1416 Digital Deskphone -...
Reset acs 308ec to factory settings
Im assuming you mean an ACS 308 processor not the 308ec expansion module. From a display phone at either extension 10 or 11 press feature 00 - left intercom button twice - #98925327
Apr 28, 2014 | Avaya Partner ACS 308EC (108463001)...
Keycode reqd
The BCM 50 can be key coded for up to 12 extensions on the main cabinet. Expansions cabinets use one key code to cover whatever Media Bay Module is installed. If you have an expansion cabinet with extensions it is possible that the extensions on the main cabinet did not get key coded. I have had a system with an expansion cabinet and only key coded eight extensions in the main cabinet because it was cheaper. This can be checked in the system / key codes area of programming.
Jul 30, 2013 | NorStar T7316E Corded Phone
Two extension phones won't ring but all other functions work fine for our AVAYA system. These extensions are plugged in to our expansion module I suspect the module is defective and need instructions on...
Power the carrier off. Pollow the power cord on the right side of the 5 slot carried. There will be a pull switch or a rocker switch. turn off.
Once power out, remove bad module, there is a tab on the top OR bottom depending on the age of your carrier. Pull card away from wall, and insert new card.
Power system back up.
Oct 08, 2010 | Avaya Partner ACS 308EC (108463001)...
We need to set up a voice mail for an extension that has not been used in years. When I press intercom 777 and enter extension it tells me to enter password which no one in the office knows anymore. When...
The default password on partner voicemails is 1234. The reason for the call returning to the extension that transferred the call to the new extension is probably because the cover vms isn't set up for the new extension.
To check the vms cover for that extension, at either extension 10 or 11 press feature 00 and press the left hand intercom button twice. The display will say system programming.
Enter #310, the display will sayAutomatic VMS Cover Extension:
enter in the extension number of the new extension.
The screen will say either "1 assigned" or "2 not assigned"
enter in 1 (assigned)
press feature 00 when finished.
Sep 30, 2010 | Avaya Corded Phone avaparp18d
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
Nortel 1140E IP Phone, Expansion Module 1100 series not working
is it a bcm 50?bcm 50 must be version 3.0 release for module to work.
Dec 09, 2008 | Nortel 1140E
Message waiting another extension
which voice mail unit do you have need to know. If panasonic vm unit after dialing into your vmail box hit #6 then *and vm box number
May 19, 2008 | Panasonic KX-TA62470-2 (KXTA624702)...
RAM extension modules for a Packard Bell Internet Dream Machine 5805i
try going to crucial.com website, they can scan your system and tell you the ram replacements or you can search for it.
Jan 22, 2008 | Packard Bell (146537-01) (14653701)...
Cisco Systems -  Unified IP Phone Expansion Module 7916 (CP-7916=) Expansion Module Logo
76 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
