I turn on the tv
I turn on my tv,after 10 minutes of normal opration it goes to standby, pliz help me
  • 2,071 Answers
This a symptom of parts joints loose connection or cold solder in power supply section and check also the electrolytic capacitor for leaky.Resolder all parts joint in power supply section.
Hope it may helps:
Regards:
VOTIT
Posted on Jun 15, 2009
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
In philips ctv model 21PT2216 tv goes to standby position while turnedon n
Do a hard reset to this TV and check whether it help you. To make it a had reset, unplug it from AC mains wall socket, and re-plug it back after 10 minutes or so. If this do not help you, the main system memory IC to your TV must be replaced.
Jan 05, 2013 | Televison & Video
Sanyo ce42f switching off
Cooling fan might be the problem. Anyhow, the TV needs servicing.
Aug 21, 2012 | Sanyo Televison & Video
Hi! My toshiba 2100td tv is over 10 years old and last few years it's having weird problems. When it's turned completely off (not in standby) and when I turn it on, the screen blinks for a 10-
The real problem here is its age, a lot of these sets of that age critically needed parts are just no longer available.
I repair them but the real risk is someone fixed it, a few months later it develops another problem etc etc etc.
Ten years is now a days a long life for a TV.
Apr 16, 2012 | Televison & Video
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Insignia 37" goes into standby mode
I am experimenting with Insignia's and there is a feature whereby if a signal is not detected the TV will switch to standby mode (in about 10 - 15 minutes). It's documented as a tiny "note" in the manual under "Understanding the basics - Turning TV on or off"
I don't know if the TV resumes when the signal is restored or if you need to power on manually.
You are probably experiencing a glitch with the signal or the TV thinking the signal is not there. Are you watching a clear picture when this happens? I would first check to see if the signal is too weak (like using a signal booster). If that is not the case, it's probably the TV acting up.
I hope this helps.
Is this
May 26, 2009 | Insignia 37" LCD Flat-Panel HDTV
My TV Screen turns green or blue after 10 minutes of the tv on
You have a chip that is overheating due to heatsink coumpound being dried up. You need to find that chip and heatsink and apply new compound to both parts.
Mar 18, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
