Question about Nordic Track Exercise & Fitness
My t5.3 has ff on display when you turn it on
Display has ff on it will not run
Display on Proform 490 LE elliptical shows FF -- How do I fix it?
1) PLEASE replace batteries by new ones.
2) clean the batteries contacts with special spray contacts cleaner
3) retight the spring contacts batteries with a pliers for better contacts very important!
4) adjust the reed switch see the diagram attached.
God bless yu
Jul 08, 2012 | Proform PFTL79807 - 850 W/ Gamefit...
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
The display reads ff and wont start
The 'ff' displayed is an error code. It means the display needs to be replaced.
To get the display replaced contact NordicTrack's customer service.
Their customer service info can be found here http://www.nordictrack.com/webapp/wcs/stores/servlet/Help_-1_10301_12401.
Mar 06, 2011 | Nordic Track NordicTrack Elite 7500...
On the display on door. The message says Er FF. What is this and how do it clear. When I press buttons, nothing changes.
Er FF is Error, Freezer Fan. The fan blade in the freezer is most likely blocked by some ice or frost. Clear that and the control will see the feedback from the fan showing that the motor is turning and the code will clear.
Feb 12, 2011 | Kenmore 73503 Stainless Steel Bottom...
We have a noritz tankless water heater that we installed & it stayed on all evening, provided hot water etc. Decided to move the display & turned off. Now when we go to turn it on, it will flash...
check the wiring connections for your remote. The FF is related to communication problems with the remote. You should also reset the unit by disconnecting electricity, waiting 20 seconds, and then reconnecting electricity to the heater.
Apr 26, 2010 | Noritz 6.3 Gallon Residential Tankless...
Ive brought a new gaming rig, as follows CPU: Athlon II X2 240, 2.8Ghz MBD: Biostar TA770E AM3 / DDR2 / SATA RAM: 2GB DDR2 800MHz Case: CoolerMaster Elite 330 PSU: WinPower 450w One 300gb Sata drive One...
These new graphics cards pull a lot of power from the power supply. I know you didn't start off having this issue but given the symptoms you are experiencing I'd take a closer look at the power supply and perhaps replace it with a 650 watt or better.
Nov 16, 2009 | Acer Aspireā„¢ T180 PC Desktop
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
How do i set the clock on my pioneer super tuner III D
To set a Pioneer clock you do this..
1. Press the Source button till only the clock is displayed, this is Stand-by mode.
2. Press & hold the "F" or function button until "menu" appears on the display. You are now in the set-up menu.
3. Using the ff/frw button go thru the choices until clock adj is displayed.
4. Using the ff/rw set the correct hour and min and hit "f" to return to your menu.
5. Also turn off or on the AUX if you want and if that model offers it.
6. Relax and chill cause now your clock is set and your early. good luck
Aug 06, 2009 | Car Audio & Video
ER FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 12, 2009 | Kenmore 77719 Side by Side Bottom Freezer...
Computer will not turn on. it is just "sparking" ie fans/lights/come on for split second and then everything goes off. on my evga motherboard there is a FF display. i have been troubleshooting easy things...
Not sure about the FF. If everything comes on and then powers off after only a split second, there is not time for the display to show anything. I'm suspecting it is indicating there is no signal.
The very first thing I would try on this computer is the power supply (assuming it's a desktop system).
A faulty power supply can act like this.
Jan 17, 2009 | Evga nForce 680i SLI (122CKNF68)...
Exercise & Fitness Logo
15 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
