Question about Xerox DocuMate 152 Pass-Through Scanner
Scanning slow my scanner is suddenly scanning really slow when its pulling the paper through.
Paper jam on scanner HP J3500
paper roller clean
OR
replace it
Feb 18, 2013 | Office Equipment & Supplies
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying!
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Brother 5750E Fax
My canon dr-3080 cii is running at a low speed. it was at its maximum and suddenly slowed down. rebooted cpu and switched scanner on /off and chcked settings with no results. please help
Scanner will continue to scan at the same Speed! The problem is in the computer. Check if you have enough disk space, do a 'defrag' on your harddisk, create extra space by deleting unwanted files. IF your processor is slow and if you are scanning in color or converting to PDF while scanning, it may slow down the output.
S. Mohan, Chennai, India
Dec 22, 2010 | Canon DR-3080CII Path-Through Flatbed...
Volvo s40 2003 diesel. all of a sudden it is very slow accelarating from a stop start. there is no pull what so ever. any ideas please.
Could have several problems. Need to have it scanned before you really know which direction to persue.
Sep 14, 2010 | 2003 Volvo S40
I am having problems with my Doucmate trying to pull more paper through to scan even though it is done scanning and then it thinks that there is a jam. When it tries to pull more paper through the...
If you pull open the front cover open you will see that the feed switch is probably stuck in the down position and not springing back up after each oage.
Jan 13, 2010 | Xerox DocuMate 152 Pass-Through Scanner
My scanjet 5590 was working ok, but suddenly stops scanning right
try reinstalling the scanner softwares and if this doesnot help do a master reset of the scanner
Jul 22, 2009 | HP Scanjet 5590 Flatbed Scanner
Canoscan 9950f red line on scan
Try running a calibration. This is done thorugh ScanGear in Advanced mode. Once in Advanced Mode, in the Image Settings section there should be an option for Calibration (you may have to scroll down in this section to see it). After running the calibration, try performing a preview scan with nothing on the scanner glass. If the red line shows up on the preview now, then most likely the scanner needs to be serviced.
Mar 12, 2008 | Canon CanoScan 9950F Flatbed Scanner
I have an X1150 and the scanner is not working properly
yeppers..the scanner mechanism is either corrupted(broken) or there's something hanging it up inside(paper jam, perhaps). sounds like the mechanicals are really unhappy here
Jan 31, 2008 | Lexmark X1150 All-In-One InkJet Printer
Will not scan
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Jun 19, 2007 | Canon PC-1080F Copier
Xerox DocuMate 152 Pass-Through Scanner Logo
43 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
