Question about Nordic Track NordicTrack - GX 2.5
No shutdown stay on
The bike doesn't shut off.it sits for hours until I unplug so I don't burn it out.is there a better fix?
Fzr 1000 engine sat then locked up
Hi, Brian ouch!!!!! this is what can happen if you don't perform winterization maintenance before you store your bike for the winter and by the way, rust never sleeps and radiator coolant loves to spend the winter in your cylinders if there is a welcome mat, ok now for some help, remove the spark plugs and squirt "Marvel Mystery Oil" down each cylinder 1 oz. per cylinder should do then with bike sitting straight up let it stay in there for 24 hours then put it in 1st gear and rock the bike back and forth until it breaks free, if it doesn't let it sit for another 24 hours and repeat the process, if it still won't break loose take it to a shop they will have more tricks to employ if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 3 years or older when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and replace the battery.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove your air cleaner and clean and re-oil per Mfg. specifications.
6. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
8. Replace spark plug with a new one and check for spark.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Exup1000 co uk Tech FZR1000R
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Yamaha FZR 1000 1992
Tips and Tricks for Motorcyclists
Apr 26, 2012 | 1992 Yamaha FZR 1000
2003 Chrysler town & country limited
First try and change the fuel filter. this also happened on a van i worked on. I cahnged the filter and it runs fine now.
Nov 16, 2011 | 2003 Chrysler Town & Country
When logging off my laptop, and before going into shutdown, I closed the lid on my laptop. The window is now stuck showing the prepare to shutdown screen. The mouse pad still works but nothing I push will...
Try holding down the power button until the computer force shuts down. If that doesn't work, you may need to pull the battery. Don't worry about damaging files, everything should be fine. When Windows boots up again, you just need to select "Start Windows normally".
Aug 14, 2011 | IBM ThinkPad T60 Notebook
My 2006 katana starts up runs for a while then shuts off
Has the bike been sitting for a while? If it has, then the carburetor(s) probably needs serviced. It might also be a clogged fuel strainer (usually located in the tank) If the service history of this bike is unknown, then check for a really dirty air filter(s). Try to keep the bike running by giving it some throttle. If it stays running, then the carburetor(s) will probably need to be cleaned and rebuilt. If it still shuts down, then verify fuel flow. Disconnect the fuel line from the carburetor(s) and observe fuel flow when the fuel valve is turned on. Fuel should flow out in a steady stream. If it doesn't, then clean the strainer. If it does, then drain the fuel out of the tank reconnect the line(s) and refill the tank with fresh fuel. If the bike has been sitting for a while, you could have a fuel volatility problem. I hope that this information helps you solve your problem. Thanks for trying FixYa.
Jul 28, 2011 | Suzuki GSX 600 F (Katana Motorcycles
My bike has sat for one year. I bought a new battery one year ago and drove it from my old apartment to my current one. The bike has not been started for one year. I got a used gas tank on ebay and...
Ok mate few things to consider here, if the bike has been non started and stationary for a year there is a very good chance that one of the following or all of the following has occurred.
Your battery is dead (they don't like just sitting - doesn't matter new or old, if left for extensive time they will die) Your gear / motor oil would be useless - oil can not just sit in bottom of bike for a year it would be glue
Your carbi would be blocked or partially blocked from fuel gum or varnish in jets
If you like this bike I highly recommend oil and filter change, New spark plug (put about 10 drops of oil down the spark plug hole before you put new spark plug back in to lube the piston) clean air filter (or fit new one) Remove carbi and compressed air clean all jets especially the pilot jet and circuit and stick in a new battery
Once all done for the fist start I would find a nice safe hill and push start it. in my experience under this circumstances if you rely on the electric starter you may find you burn it out trying to start so give at least few minutes running motor to flush everything through before trying to electric start would be your best bet
When you get it going I would dump the oil and oil filter again after 2 hours ride time to confirm all the old expired oil is flushed out - just to be safe
good luck regards Jamie
May 28, 2011 | Suzuki Boulevard C50T Motorcycles
Heating up, shuts off, Shutting off going about an 1 hour trip. hearing small noise in front of engine. Seams to be running hot. service techs put it on dyna but no results. Shut off again next trip. ran...
Had a simuliar problem, Bike would have a total shutdown a High Temps/Low Speeds/High RPMs. Everything would reset itself after appox 2 minutes. Everything would shutdown Electric and engine.
2 Harley dealers spent 75 hours diagnosing it, dealer could not reproduce it. Last repair was to replace battery cables. Seems to have fixed it. Have ridden 15oo miles since repair. Problem reacurred once last time I rode. Again complete shutdown bike restored after 2 minutes. Did not happen again the rest of the day over 200 miles
Aug 30, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
My laptop screen will not shut off. I have a Sony Vaio about 6 years old. When I power down the screen shuts off while everything is shutting down but then when everything is off the monitor turns a light...
if u r using vista sure check the shutdown button.
or press once power button it automatically shutdowns
or hold power button until it shut down
when u close the door it only standby..
Oct 22, 2009 | Dell Inspiron E1405 Notebook
My Stilletto 10 doesn't reliably record programmed talk shows. I leave it on and plugged into my car kit (yes, it is powered by a plug that stays on when the car is off) and when I come back it is...
Is it set for auto shut down? It took me months to properly record with this thing, frustrating at best. Now it's almost flawless. Go in to menu then settings then dock. In that menu you will see "Auto Shutdown". If this is on, your receiver will shut off after 4 hours only when plugged into the car dock. When on a home dock it will stay on. Turn this off and it will stay on until you shut down. Auto shutdown is the default setting. If for some reason you receiver is reset, you will need to check this setting again, because it will turn auto shutdown on again. Hope this helps.
Jul 17, 2009 | Sirius STILETTO 100 MP3 Player
Nordic Track NordicTrack - GX 2.5 Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
