Question about Bishamon UNI-20 - UniLift Pallet Transporter and Positioner
Will not go up and all the red lights are on.
Both swing arms are in the retracted position, but it will not go up. On the control panel all the red lights are lit.
Changing a rear coil spring on a 05 echo
Jack up both sides of the rear of the car. LOWER ONTO AXLE STANDS. You will need the jack for another job.
Use the jack to GENTLY take the weight of the swing arm. (Marked A). Just enough to allow you to remove the bottom bolts through BOTH dampers, (Marked B). SLOWLY and GENTLY lower the jack and both springs, (marked C), should become loose enough to pull out.
Refit...
ea95d7d4-1661-453b-a221-57b1993e0768-gdwjs3mziq0tgl1byg3c3jnn-3-0.jpeg Insert the springs and slowly jack up the swing arm (A) until it is nearly in position. Make sure the springs (C) are seated properly, then gently jack up the swing arm until you can re-insert the damper bolts, (B). Once they are the correct tightness, GENTLY lower the swing arm. Check the springs are in position and drop the swing arm all the way.
Raise the car and remove the axle stands.
Jan 23, 2018 | Cars & Trucks
Attach bagger to john deere d140
While standing at back of mower with the bagger hood in your hands. The black support arm is hanging down, positioned at the back of the mower. At the bottom of the black support arm are two tangs with a gap between them (gap is 2"-3"). The tangs will be inserted into two slots on the towing frame. That is the black panel of the back of the mower. They will not be centered; rather they will be offset to the right side of the tow frame, about mid way up the back.
Lower the hood support so the tangs are horizontal, or parallel to the ground. Once parallel to the ground they will slide into the slots. After they are in the slots, while holding the black support arm steady, raise the two swing arms up to the seat. After raising the swing arms (light brassy color, V shaped connecting rods) then raise the black support arm with the tangs held in the slots. As you raise the black support arm vertically the swing rods will move forward, over the top of the fender, and align with two retaining holes.When the hood is level with the top of the seat you will be able to insert the ends of the swing arms into the holes in the fenders. This will complete installation of the support for the bagging hood. Now follow the locking instructions below.
Note: prior to starting this procedure you may have to remove a spring clip and locking pin (about 6" long and 1/4" round) that runs through the black support arm. It runs right to left through two holes in the support arm, the spring clip locks it in. This pin may be supplied uninstalled. The function of the 6" locking pin is to keep the swing arm in the fender holes after you have everything in place. It must be removed to perform the above installation. After the installation is complete insert the lock pin, right to left, pointy end goes in first, above the swing arms where they meet the black support arm, then insert the locking spring clip in the tiny hole of the locking pin. This locks the swing arms in place.
Oct 12, 2014 | John Deere Garden
I have a ford escort 1.8 diesel. after spending a lot on pump overhaul , she rufuses to start in the mornings. i noticed that the wires from the solenoid switch had broken. i cut of old wires and rejoined...
yes --fully retracted so that the valve or governor arm can go to the full fuel position
when turned off , the spring in the solenoid pushes the lever forward to shut off the fuel
Aug 05, 2017 | Ford Escort Cars & Trucks
In the treadclimber mode. One side or the other will stay down as it should come back up with the other. What should I do?
pull adjustment knob out.Set the swing arm in the position hightest and release the knob to lock the arm in place.
Look at the clips at the end of the cable.If they hang down and are not tight againt the pulley,tight the pulley.
locate the tension knob in the side- Pull the knob and turn the pulley bellow the know clockwise.
Watch the clip above you retract.Stop turning the tension knob when the clip touches the pulley.
Repeat with the other cables. sincerely
Sep 22, 2011 | Bowflex Treadclimber
My Hp colorlaserjet 37ooDN is showing the error : 59.C0 Pl. HELP
59.C0 Error Displayed on Control Panel Remove all the print cartridges from the printer so the right swing guide will be visible and check for the parts described in the photos below.
If the right side swing guide does not go all the way back, the 59.C0 alienation error will be displayed on the control panel. A plastic part on the swing guide could be missing.
See photo below where the three circles are on the right side of the printer.
Figure 1: Right swing arm assembly
37001See photo for details of the part. Call-out 1 in the photo below shows the parts in place, while Call-out 2 shows the missing part. (The part looks like an upside-down t.)
Figure 2: Missing part causing 59.C0 error
370021 - Part in place
2 - Part missing
Another cause for a 59.C0 error can be the black sliding lock is broken, out of place, or missing the spring. (See figure below) This can cause 59.C0 errors or 10.92.XX errors.
Figure 3: Right swing frame assembly
37003Replace the swing guide. Please look for the missing part in the printer so it will not cause other issues from movement to other parts of the printer.
If the part in the call-out is present, close the door slowly and observe the right side swing arm. It should close uniformally with the left side swing arm. If not, arrange for service on the printer and replace the right swing arm.
Jun 20, 2011 | HP LaserJet 3700dn Printer
My pfaff embroidery arm is stuck in the open position and I cannot close it. What should I do?
The embroidary arm swings clockwise to use and counter clockwise to store. Lift up at the pivot point on the arm to swing from one position to the other.
May 12, 2011 | PfaFF Creative 7570
Windshield wipers work but stop in the up position.
the problem with your wipers is that your wiper switch is going bad that is one of the signs, they will eventually go all the way out and wont even come on at all, replacing the switch will cure most likely cure your wiper problem.
Jan 02, 2011 | 1997 Pontiac Sunfire
Have a DC25, I can not return the handle to the upright position. Nothing appears to be broken
Occasionally, customers have problems locking their Dyson vacuum in the upright position. This is a minor problem common with the Dyson DC07 and DC14 series and can easily be fixed by the customer. This page will show how to fix this problem. Although we show a Dyson DC14 Animal on this page, these instructions will work on any Dyson vacuum in the DC07 and DC14 series.
During shipping, moving parts on a Dyson vacuum can shift in position. One of these parts is a swinging arm in the base of the unit. This arm holds a removable elbow pipe in the vacuum's air passage. This arm can move out of the way so that you can clear out a blockage in the air passage. When this arm is out of position, the vacuum will not lock in the upright position. Fig. 1 Shows the base of a Dyson DC14 Animal locked upright. The red arrow points to the swinging arm. Fig. 2 shows the vacuum with the swing arm out of position. Since the swing arm is lower than it should be, it doesn't line up with the tab on the main body indicated by the red arrow.
Lean the handle of your Dyson all the way back and locate the black button on the right side of the vacuum indicated by the red arrow in Fig. 3.. Press the button down and hold it to unlock the swing arm.
While holding down the black button, pull the swinging arm (Shaded red in Fig. 4) all the way up. Fig. 5 shows the swinging arm in the correct position. Release the black button to lock the swing arm back in place.
The vacuum can now lock in the upright position as shown in Fig. 6. Note how the tab on the swinging arm overlaps the tab on the main body..
dcramer531_17.jpgdcramer531_18.jpgdcramer531_19.jpgdcramer531_20.jpgdcramer531_21.jpgdcramer531_22.jpg
Dec 11, 2010 | Dyson DC25 All Floors Bagless Upright...
I have a 1996 pontiac sunfie 2.2 auto
on this year car there was a problem with the circut boad in the wiper moter, the parking position on the board is broken,you just have to replace the circuit not the motor hope this helps. Thanks Ray, please rate my fix
Feb 06, 2010 | 1996 Pontiac Sunfire
Bishamon UNI-20 - UniLift Pallet Transporter and Positioner Logo
685 people viewed this question
Top Bishamon Hoisting Experts
gbob59
Andrew Taylor
Andrew Taylor
Are you a Bishamon Hoisting Expert? Answer questions, earn points and help others
