Question about Acer PalmPro 7765PE Multimedia Projector
Adapter I have a multimedia adapter palmpro series...can you tell me anything about what it is used for
I can't install my audio driver in my PC
it is difficult to say anything about your audio driver bcuz you have not cleared here about your system series or motherbord you are using.
so kindly plz write your computer model or series then i can give you some troubleshoot tips for ur audio driver ......
Apr 20, 2010 | Intel REALTEK nc-r150201 Network Adapter
Can this HP Pavilion DV9000 laptop adapter fit for Compaq Presario V3000 laptop? I doult that HP Pavilion DV9000 laptop adapter on website:http://www.laptopbatteryshop.ca/hp-pavilion-dv9000-ac-adapter.htm...
Have a look at the label on the bottom of the V3000 laptop and check the voltage and amps power rating of the laptop.
If the DV9000 adapter has the same voltage and current rating (amps) or higher amp rating then it is suitable for the V3000 laptop, provided the power plug fits the V3000 power socket.
Jan 15, 2010 | Dell Inspiron 1525 Laptop
Is this model wifi enabled
You have not given your laptop specific model number! In any case, the Presario 2200 series of laptop normally come with Wifi adapter as standard. To check, use windows 'Device Manager' and locate the 'Network adapters' node: this will tell you for certain what network adapters are available.
Hope it helps. Let me know how you go or if you need further assistance.
Jan 08, 2010 | HP Compaq Presario 2200 Notebook
Hitachi projectors cp rx60 cp r555 same remote control?
Specifically i don't know. What i do know is mfg's use the same codes, whether they map them to the same functions across a series of remotes can't say for sure. Experiance tells me it will be just fine...
Jun 10, 2009 | Hitachi CP-S335 Multimedia Projector
Connecting Ibook G4 to Sanyo PRO xtrax projector
Most of the Apple iBook G4 series have a video out port on the left side. This is a non-standard port and would require the use of an adapter (Apple VGA Display Adapter) that is normally included with the laptop package when first bought. The VGA's output connector is the standard 15 pin HD D-Sub (HD-15).
On the other hand, the Sanyo PRO XTRAX projector is capable of multiple input type of connectors. They are: a) RCA type composite video in, b) DVI, c) RGB, c) RS232, d) S-Video, e) USb and f) VGA. You would then be using the latter, VGA since it matches the Apple VGA Display Adapter.
To connect the iBook to the projector, you would need a length of VGA cable that are available in most projector/computer stores. Here, here and here are examples of commercially available.
Hope this be of some help/idea. Pls post back how things turned up or should you be in need of additional information.
Good luck and kind regards.
Feb 02, 2008 | Sanyo PLC XU33 Multimedia Projector
I just received the Garmin C340 GPS as a gift from my daughter.
Only use Garmin approved power connector either AC or DC (cigarette lighter adapter), otherwise you risk ruining your unit. The DC power adapter actually step down the voltage from 12vdc to 5vdc. Using anything other than a Garmin approved adapter can fried the unit.
Jan 21, 2008 | Garmin StreetPilot c340 GPS Receiver
No sign of connection to computer
what model projector? i'd need that in order to help.
Jul 03, 2006 | InFocus MULTIMEDIA ADAPTER WRAP,...
Acer PalmPro 7765PE Multimedia Projector Logo
37 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
