Question about Magic Chef MCD1311ST Microwave Oven
FUSE how to change the fuse
How to change fuse in microwave
There will be more than one fuse. One will be on the main printed circuit board near where the supply wires connect, The other will be the HV fuse in the magnetron circuit.
If you do not have the right test instruments then don't try this repair yourself. The magnetron circuit can deliver a lethal shock even when the oven is not plugged in to the wall.
It may be uneconomical to have it repaired, given the cost of new ones, so get a quote before going ahead.
Dec 15, 2015 | In Microwave Ovens
How to know when a fuse is burned in my lg microwave?
By looking at it, if the metal strip is melted/broken the fuse is bad. Using a VOM to test it. Remove one side of the fuse from the holder, put one lead on each side of fuse. meter indicates 0.00 fuse is good, meter reading does not change fuse is bad. Electonis fuses can only be checke with a meter not visualy.
Aug 11, 2014 | LG Over-the-Range Microwave
How to change a fuse in frigidaire microwave?
Good Morning Friend,
I understand you want to know how to change a fuse in your Frigidaire microwave. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to change out the fuse with ease. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Over-the-Range Microwave
Short Circuit in changing light bulb in KHMS147SS has caused the unit to power completely down. Is there a fuse?
see this causes and fix it. God bless you
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 23, 2012 | Microwave Ovens
Won't heat food on any setting. Could it be a fuse? Where would it be located? Don't have a manual.
Fuse will be inside the oven.And with replacing fuse ,you need to check the cause of blowing the fuse.Check the capacitor and transformer (physically).If they look deformed .Then change it followed by the fuse.
Thanks
Please rate my work
Sep 17, 2011 | Daewoo KOR-630A Microwave Oven
Is it possible to blow a fuse on a micro oven? And where would I change it?
There is a fuse found behind the upper grill, it is likely a 20amp fuse.
If the fuse has blown, it is likely that the door safety switches need to be replaced.
Change the fuse (unplug the micro first) and continue using. If the fuse blows again, have it serviced by a qualified service person.
Dec 30, 2010 | Goldstar MV-1502 Microwave Oven
Where is the fuse
remove the outer cover and the fuse is either on top or on the side in a fuse holder clip,it takes a special "ceramic-fuse" available at hardware stores, if it blows again.suspect a h.v. capacitor,diode,magnetron, or exposed wire arcing
Apr 19, 2010 | Emerson MW8107WA Microwave Oven
The house fuse that runs the circut the microwave is on blew when replaced the microwave did not come back on,is there a reset button or fuse on it.
There is a fuse inside the microwave oven but i don't recommend opening the oven and changing it. There are high voltages inside even when the oven is disconnected from the mains.
But if you are careful enough, you can change it. If it has a electronic control (With a digital display) maybe there is another fuse on the controller board, near the front panel.
Before even opening the oven, make sure it doesn't work on another power outlet.
And make sure you change it with the same type and rating of fuse!
Oct 27, 2009 | Magic Chef Microwave Ovens
Just suddenly stop heating - can't find any microwave service.
Did you change the diode as well, if not you need to change it if there nothing wrong problem is a bad magnetron
Professional appliance repair in Los Angeles, California.
Aug 04, 2009 | Sanyo Microwave Ovens
Magic Chef MCD1311ST Microwave Oven Logo
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
